How to fix E: Internal Error, No file name for libc6, Like that will show If I do:
$ sudo apt-get upgrade
or
$ sudo apt-get install package
This is example :
Reading package lists... Done
Building dependency tree
The following packages have been kept back:
ginn hplip hplip-data libdrm-dev libdrm-intel1 libdrm-nouveau1a
libdrm-radeon1 libdrm2 libgrip0 libhpmud0 libkms1 libsane-hpaio
libunity-2d-private0 libunity-core-5.0-5 linux-generic-pae
linux-headers-generic-pae linux-image-generic-pae printer-driver-hpcups
printer-driver-hpijs unity unity-2d-common unity-2d-panel unity-2d-shell
unity-2d-spread unity-common unity-services
The following packages will be upgraded:
alsa-base firefox firefox-globalmenu firefox-gnome-support firefox-locale-en
icedtea-6-jre-cacao icedtea-6-jre-jamvm icedtea-7-jre-jamvm libdbus-glib-1-2
libdbus-glib-1-dev libgnutls-dev libgnutls-openssl27 libgnutls26
libgnutlsxx27 libssl-dev libssl-doc libssl1.0.0 linux-sound-base
openjdk-6-jre openjdk-6-jre-headless openjdk-6-jre-lib openjdk-7-jdk
openjdk-7-jre openjdk-7-jre-headless openjdk-7-jre-lib openssl sudo
27 upgraded, 0 newly installed, 0 to remove and 26 not upgraded.
3 not fully installed or removed.
Need to get 0 B/126 MB of archives.
After this operation, 3,072 B of additional disk space will be used.
Do you want to continue [Y/n]? y
I have follow instruction from here How to resolve E: Internal Error when using apt-get remove? . Which do:
sudo apt-get update
sudo apt-get clean
sudo apt-get install -fy
sudo dpkg -i /var/cache/apt/archives/*.deb
sudo dpkg --configure -a
sudo apt-get dist-upgrade
But stuck with same error E: Internal Error, No file name for libc6 when do command sudo apt-get install -fy.
And I've been looking on google, but have not been successful until now.
Thanks.
