16
I use:
apt-get remove
To remove some software, but it displays:
error:E: Internal Error, No file name for libssl1.0.0 .
I also try this to resolve the error:
wget http://launchpadlibrarian.net/102991621/libssl1.0.0_1.0.0e-2ubuntu4.5_i386.deb
sudo dpkg -i libssl1.0.0_1.0.0e-2ubuntu4.5_i386.deb
But it also gives an error :
 libssl1.0.0:i386 1.0.0e-2ubuntu4.5 cannot be configured because libssl1.0.0:amd64 is in a different version (1.0.1-4ubuntu5.3)
I want know the correct way to solve this problem.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
yue
  • 161
5 Answers5
23
For me this works:
sudo dpkg --configure -a
Src: E: dpkg was interrupted... run 'sudo dpkg --configure -a'
Reboot then,
apt-get update
apt-get upgrade
I hope it works for you too!
I also encountered this error on Ubuntu 12.04. I fixed it with the following commands:
sudo apt-get update
sudo apt-get clean
sudo apt-get install -f
sudo dpkg -i /var/cache/apt/archives/*.deb
sudo apt-get dist-upgrade
mchid
  • 44,904
  • 102
  • 162
use dpkg -i on both of these:
http://security.ubuntu.com/ubuntu/pool/main/o/openssl/libssl1.0.0_1.0.1-4ubuntu5.3_i386.deb
http://security.ubuntu.com/ubuntu/pool/main/o/openssl/libssl1.0.0_1.0.1-4ubuntu5.3_amd64.deb
Thomas Ward
  • 78,878
user72421
  • 3,711
My problem stemmed from an unmet dependency for rhythmbox. Just the following 3 commands got rid of the dependency and error. These are from a previous posting.
error: E: Internal Error, No file name for libssl1.0.0
I just entered
sudo apt-get update
sudo apt-get clean
mchid
  • 44,904
  • 102
  • 162
ratman
If the suggestion
does not work for you, try to reinstall both packages libssl1.0.0:i386 and libssl1.0.0:amd64. You might have to force this because you temporarily break dependencies until these packages will have been reinstalled with the fourth of the followting command:
sudo dpkg --purge --force-depends libssl1.0.0:i386
sudo dpkg --purge --force-depends libssl1.0.0:amd64
sudo apt-get -f install
Alex1357
  • 1,192
