When trying to switch 14.10 to systemd I've run into a situation: I can not remove package 'nvidia-prime' and it prevents me to install either upstart or systemd, so now my machine will not reboot. How can I force dpkg to remove that dumb package?
dpkg --force-all -P nvidia-prime
(Reading database ... 204460 files and directories currently installed.)
Removing nvidia-prime (0.6.7) ...
Failed to issue method call: Unit nvidia-prime.service not loaded.
invoke-rc.d: initscript nvidia-prime, action "stop" failed.
dpkg: error processing package nvidia-prime (--purge):
 subprocess installed pre-removal script returned error exit status 5
Failed to issue method call: Unit nvidia-prime.service failed to load: No such file or directory.
invoke-rc.d: initscript nvidia-prime, action "start" failed.
dpkg: error while cleaning up:
 subprocess installed post-installation script returned error exit status 6
 nvidia-prime
root@Shamaniak:~# dpkg -P nvidia-prime
 nvidia-prime
apt-get install -fm upstart
Reading package lists... Done
Building dependency tree
upstart is already the newest version.
upstart set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n]
Setting up nvidia-prime (0.6.7) ...
dpkg: error processing package nvidia-prime (--configure):
 nvidia-prime
apt-get install systemd-sysv
The following packages will be REMOVED:
  nvidia-prime upstart
The following NEW packages will be installed:
  systemd-sysv
0 upgraded, 1 newly installed, 2 to remove and 0 not upgraded.
Need to get 0 B/8 548 B of archives.
After this operation, 700 kB disk space will be freed.
dpkg: error processing package nvidia-prime (--remove):
dpkg: upstart: dependency problems, but removing anyway as you requested:
 friendly-recovery depends on upstart | systemd-sysv; however:
  Package upstart is to be removed.
  Package systemd-sysv is not installed.
 nvidia-prime depends on upstart.
Removing upstart (1.13.2-0ubuntu2) ...
Processing triggers for man-db (2.7.0.2-2) ...
 nvidia-prime
root@Shamaniak:~# apt-get purge nvidia-prime
You might want to run 'apt-get -f install' to correct these:
 friendly-recovery : Depends: upstart or
                              systemd-sysv but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
root@Shamaniak:~# apt-get -f install
Correcting dependencies... Done
The following extra packages will be installed:
  upstart
Suggested packages:
  graphviz upstart-monitor
  upstart
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/118 kB of archives.
After this operation, 671 kB of additional disk space will be used.
Selecting previously unselected package upstart.
(Reading database ... 204423 files and directories currently installed.)
Preparing to unpack .../upstart_1.13.2-0ubuntu2_amd64.deb ...
Unpacking upstart (1.13.2-0ubuntu2) ...
Processing triggers for dbus (1.8.8-1ubuntu2.1) ...
Setting up upstart (1.13.2-0ubuntu2) ...
 nvidia-prime
root@Shamaniak:~# sudo apt-get install --reinstall nvidia-prime
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
E: Internal Error, No file name for nvidia-prime:amd64
I did it. Had to actually dig into that package scripting
cat /var/lib/dpkg/info/nvidia-prime.postinst
There I saw it checked for existance of /etc/init.d/nvidia-prime so I created it.
touch /etc/init.d/nvidia-prime
Then the package cordially allowed to reinstall itself and then delete.
-1
Here is link of almost same suiting answer to your intention.
The package nvidia-prime should work perfect. It is obviously fact that your nvidia-installations are "over-done" somehow. Like described in steps here :
I would try following in case the installation is a bit overdone :
sudo apt-get install ppa-purge
sudo apt-get purge nvidia*
sudo ppa-purge ppa:xorg-edgers/ppa
sudo reboot
Back into terminal, simply try this only :
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt-get update
then this here :
sudo apt-get install nvidia-358 nvidia-prime
sudo apt-get install --reinstall xserver-xorg
sudo reboot
please answer as comment if this was of help for this situation of yours.
(reference from :
Dual monitor not working - Intel Graphics & Nvidia 960m )
dschinn1001
  • 3,863
