How can I switch the command output language from my native language to English, so I can post my Ask Ubuntu question with English command output (error messages)?
export LC_ALL=C is enough. All subsequent command output will be in English.
More information: What does "LC_ALL=C" do?
If you want to revert to the native language, unset the LC_ALL variable:
unset LC_ALL
- 55,453
bash function for terminal
Here is my bash function to switch between DE and EN locales.
You may extend this code with your preferred languages.
To use this, put it in your ~/.bashrc (or ~/.bash_profile)-
Call it with _configure_locale EN to switch to English.
function _configure_locale() { # [profile]
local profile=${1:-EN}
case ${profile} in
DE|DE_DE|de_DE)
LC_ALL="de_DE.UTF-8"
LANG="de_DE.UTF-8"
LANGUAGE="de_DE:de:en_US:en"
EN|EN_US|en|en_US)
LC_ALL="en_US.UTF-8"
LANG="en_US.UTF-8"
LANGUAGE="en_US:en"
echo "ALERT" "${FUNCNAME}: unknown profile '${profile}'"
esac
LC_PAPER="de_DE.UTF-8"; # independent from locale
LESSCHARSET="utf-8"; # independent from locale
MM_CHARSET="utf-8" # independent from locale
echo "locale settings" "${LANG}";
export LC_ALL LANG LANGUAGE LC_PAPER LESSCHARSET MM_CHARSET
In general I suggest to change all 3 environment variables LC_ALL, LANG, LANGUAGE to avoid misbehaviours of some programs.
Adapting to your language
Extending the code to your native language is quite simple. You can find the needed values by invoking the following command
env |egrep -e 'LC_ALL|LANG'
- 13,475
- 4,851
Open a terminal Ctrl+Alt+T and type:
LANG=en_US.UTF-8 bash
or:
LC_ALL=C bash
Now the terminal output is in english language. You can check it with locale.
It is possible to make a command to do that with a permanent alias. Open the .bashrc file with your preferred editor and put the following code in there:
alias basheng='LANG=en_US.UTF-8 bash'
or:
alias basheng='LC_ALL=C bash'
Restart the Bash shell. Now you have the command basheng. Type it in the Bash to get an english Bash shell. To leave the english shell type exit.
Source:
This is configured via locale settings, which can be set via environment variable. There are four layers of variables; the first one that is set takes precedence:
LANGUAGE— don't use it, it's rarely useful and can cause bugs. Unfortunately, some versions of Ubuntu set it, so you may need to unset it.LC_ALL— overrides category-specific settings, meant primarily to be used by programs that want to run in the default locale. Not meant to be used as global settings.- Category-specific variables beginning with
LC_:LC_CTYPE,LC_MESSAGES,LC_TIME, …. LANG— sets the default locale for all categories, meant to be used in a global user settings.
The “plain” locale, with all messages untranslated, default time and number formats, ASCII as the character set, etc. is called C. This locale is present on every system.
Thus, to run a program with messages in English, run
unset LANGUAGE; LC_MESSAGES=C myprogram --option
or
unset LANGUAGE
export LC_MESSAGES=C
myprogram --option
myotherprogram
To run a program with all localization turned off, run
env -u LANGUAGE LC_ALL=C myprogram --option
but beware that this switches the character encoding to ASCII (so no Unicode, latin-1, etc.).
See What should I set my locale to and what are the implications of doing so? for a more detailed overview of locales.
- 61,858
in your ~/.bashrc
unset LC_ALL
then
source ~/.bashrc
Check it
$ locale
LANG=pl_PL.utf8
LANGUAGE=
LC_CTYPE="pl_PL.utf8"
LC_NUMERIC="pl_PL.utf8"
LC_TIME="pl_PL.utf8"
LC_COLLATE="pl_PL.utf8"
LC_MONETARY="pl_PL.utf8"
LC_MESSAGES=C
LC_PAPER="pl_PL.utf8"
LC_NAME="pl_PL.utf8"
LC_ADDRESS="pl_PL.utf8"
LC_TELEPHONE="pl_PL.utf8"
LC_MEASUREMENT="pl_PL.utf8"
LC_IDENTIFICATION="pl_PL.utf8"
LC_ALL=
Why unset first?
LC_ALL Overrides individual LC_* settings: if LC_ALL is set, none of the below have any effect.
- 240
Related bug to language change/switching settings in Fedora(30) ex: ENG to Native to ENG
There is env variable that doesn't change back to EN, namely for example from Bulgarian (bg). Example:
# LANGUAGE=en_GB:bg
has to change to:
# LANGUAGE=en_GB:en
Solution(remove # and execute):
# export LANGUAGE=en_GB:en
- 139
To change the terminal language to English permanently, use:
echo 'export LANG=C' >> ~/.bashrc && exec "$BASH"
- 115
Easiest way is to open the terminal by pressing Alt+F2 and running this command:
env LANGUAGE=en gnome-terminal
- 34,191
- Click on the gear icon on the left (system settings on Unity panel)
- Click on Language Support
- Select Regional Formats
- Set your "Display numbers, dates, and currency amount ..." to English.
- Logout the session and Login again (Required!)
Done.
- 123
