I installed R on my computer, but the version was too old so I removed it. I wanted to install another one but I couldn't. I used this command:
sudo apt-get install r-base
I got this message:
Les paquets suivants contiennent des dépendances non satisfaites :
 r-base : Dépend: r-base-core (>= 3.3.3-1xenial0) mais ne sera pas installé
          Dépend: r-recommended (= 3.3.3-1xenial0) mais ne sera pas installé
          Recommande: r-base-html mais ne sera pas installé
E: Impossible de corriger les problèmes, des paquets défectueux sont en mode « garder en l'état ».
It means that there's a problem with dependencies. How can I fix it?
Zanna
  • 72,312
It appears that you are missing a couple of dependencies for the R version you are attempting to install.
Specifically, r-base-core and r-recommended of versions = or greater than 3.3.1
Compatible versions are available in Ubuntu 16.10 (and beyond) by enabling the Universe repository and issuing the command
sudo apt-get install r-base-core r-recommended
If you are running an earlier version of Ubuntu you'll have to either upgrade to 16.10 or use a version of R supported by your current OS.
Elder Geek
  • 36,752
