I'm fairly new to Linux and Ubuntu, and I recently wanted to install TF2 on Ubuntu. When I tried to install it through Steam it said TF2 was about 11GB and I there was only 2GB available so I couldn't install it.
So I checked my harddrive and my external one I was running Ubuntu on, the external one had at least 400 Gigabytes free and the other one had about 180.
What's going on? and How do I fix it?
Output of df -h
Filesystem Size Used Avail Use% Mounted on
/dev/loop0 3.9G 1.1G 2.6G 30% /
udev 1.9G 4.0K 1.9G 1% /dev
tmpfs 752M 908K 751M 1% /run
none 5.0M 0 5.0M 0% /run/lock
none 1.9G 868K 1.9G 1% /run/shm
none 100M 56K 100M 1% /run/user
/dev/sdb1 466G 20G 446G 5% /host
/dev/loop1 3.9G 2.1G 1.6G 58% /usr
/dev/loop2 3.9G 840M 2.9G 23% /home
/dev/sda3 454G 286G 168G 64% /media/isaac/Acer
So I tried adding a library folder in /media/isaac/Acer but this error came up in steam:
"New Steam library folder must be on a filesystem mounted with execute permissions"
I have never seen this error before and I did a bit of research about it and I still have no idea how to fix it. A bit of information I don't know if this helps but I think (it might be FAT 32, neeed to double check) I'm running Ubuntu off a NTFS External hard drive.
