I am new to Ubuntu and Linux. I have a WUBI installation within Windows 7.
The issue I am having is that I can't seem to modify Windows files from Ubuntu. I can access and see all the files and folders but I can't for example make a new folder in the Windows files/folders (Permission Denied) but I can save documents, etc. to existing folders.
Is there a way of doing this?
Braiam
  • 69,112
am767
The partition where you install ubuntu is inside windows partition which is your host and it uses ntfs file system. So, you can't use chown, chmod and chgrp command to change the file permission.
Don't be dis-hearted just change one line in the file /etc/default/grub
To :- GRUB_CMDLINE_LINUX_DEFAULT="rootflags=umask=002,uid=1000,gid=1000 quiet splash"
After you make the changes save the file, you need to run
sudo update-grub
afterwards to update /boot/grub/grub.cfg
WARNING: These changes give you full access to all your files on your host, including system files and it is very very dangerous, so make sure to stay away from system folders ie. your windows system and only try this when you really really need to
For reference you may visit Changing file permission on host in Wubi & How to change file permissions of host in Wubi?
Namshum
  • 1,825
  • 25
  • 32
