I'm running Ubuntu on my Thinkpad T60. Is there a way to get the middle button to act like a scroll like it would when it runs Windows?
I'd like to be able to hold the middle button down and scroll down a webpage using the red button.
http://www.eastwoodzhao.com/thinkpad-middle-button-scroll-ubuntu-linux-10-04-lucid-lynx/
In short, run this: gksu gedit /usr/lib/X11/xorg.conf.d/20-thinkpad.conf and put this in the file:
Section "InputClass"
Identifier "Trackpoint Wheel Emulation"
MatchProduct "TPPS/2 IBM TrackPoint|DualPoint Stick|Synaptics Inc. Composite TouchPad / TrackPoint"
MatchDevicePath "/dev/input/event*"
Option "EmulateWheel" "true"
Option "EmulateWheelButton" "2"
Option "Emulate3Buttons" "false"
Option "XAxisMapping" "6 7"
Option "YAxisMapping" "4 5"
EndSection
Save and restart.
ThinkWiki has instructions on how to do this. Specifically, how to use xinput(1) to configure the TrackPoint.
(All in all, ThinkWiki is a great resource. It's pretty much the go-to place for just about anything on running Linux on Thinkpads.)
I use the following in my AwesomeWM autostart file:
# make the mouse work right on my thinkpad in lucid
xinput set-prop 'TPPS/2 IBM TrackPoint' "Evdev Wheel Emulation" 1
xinput set-prop 'TPPS/2 IBM TrackPoint' "Evdev Wheel Emulation Button" 2
xinput set-prop 'TPPS/2 IBM TrackPoint' "Evdev Wheel Emulation Timeout" 200
In the default Gnome install you could write a script that runs on boot or perhaps check out if the .xinitrc or .Xresources is used. (I can't recall which is used any more)
Gpointing is a graphical application for the gnome desktop to achieve the same result ;)
With Ubuntu install it in a terminal
sudo apt-get install gpointing-device-settings
or via software center "gpointing-device-settings"
In Ubuntu 14.04, these settings are in /usr/share/X11/xorg.conf.d/11-evdev-trackpoint.conf. It looks like this:
# trackpoint users want wheel emulation
Identifier "trackpoint catchall"
MatchIsPointer "true"
MatchProduct "TrackPoint|DualPoint Stick"
Option "Emulate3Buttons" "true"
EndSection
To get "natural scrolling", that is, scrolling in the direction of the pointer, you can swap the YAxisMapping values to be "5 4" instead. I restarted after I swapped mine and it worked fine.
