51
In Windows, you have these shortcuts:
  • WinArrow Up ↑: Maximize current window
  • WinArrow Down ↓: Unmaximize
  • WinArrow Right →: Maximize, set width as half the screen width, stick window to the right
  • WinArrow Left ←: Maximize, set width as half the screen width, stick window to the left
I’m particularly interested in the last two shortcuts.
I use the "grid" option of CompizConfig Settings Manager. "Grid" is developed as an extra plugin, so you have to install compiz-fusion-plugins-extra Install compiz-fusion-plugins-extra package (I couldn't see this in "software center", so did it through synaptic).
Once you have the plugins installed, in CCSM, go to "Window Managment", then select "Grid". I modify my "put left" to be CTRL + SHIFT + left arrow (and do likewise for "put right", "put top", and "put bottom"). I map CTRL + SHIFT + enter to be "put center".
I am not sure about W7, but the GREAT thing about GRID is that if you hit it once, it will go to half the screen. A second time goes to 1/3 of the screen. A third time has it take up 2/3 of the screen. Then, a fourth has it back to half. So, you can set up documents side by side that need 1/3 or 2/3 of the screen as well as equally sharing 1/2 of the screen.
A MUST plugin for me in Linux! And it works great!
Unity will be coming with a "snap feature" included, but I like the keyboard to do this setup for me! CCSM GRID it is!
rik-shaw
  • 864
17
For Ubuntu 11.04 (natty) and 11.10 (oneiric) you can do it if you have a keypad/number pad on your keyboard. Nothing else needs to be installed:
Ctrl + alt + NumPad 4 (entire left side)
Ctrl + alt + NumPad 5 (maximize)
Ctrl + alt + NumPad 6 (entire right side)
Ctrl + Alt + NumPad 9 (top right corner)
Full list: In the "Window Placement" of What are Unity's keyboard and mouse shortcuts?
dgo.a
  • 306
14
It worked for my Ubuntu 14.04. Just do the same thing you did in windows, but this time add Ctrl, so it's Ctrl+Super+Arrow.
David Foerster
  • 36,890
  • 56
  • 97
  • 151
ArrowsX
  • 141
