52
administrator@zlounes:~$ sudo apt-get dist-upgrade
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
 linux-server : Depends: linux-headers-server (= 3.2.0.37.44) but 3.2.0.37.45 is installed
E: Unmet dependencies. Try using -f.
administrator@zlounes:~$ sudo apt-get -f install
Correcting dependencies... Done
The following extra packages will be installed:
  linux-image-server linux-server
The following packages will be upgraded:
2 upgraded, 0 newly installed, 0 to remove and 9 not upgraded.
4 not fully installed or removed.
Need to get 0 B/4,458 B of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? y
Traceback (most recent call last):
  File "/usr/bin/apt-listchanges", line 237, in <module>
    main()
  File "/usr/bin/apt-listchanges", line 48, in main
    debs = apt_listchanges.read_apt_pipeline(config)
  File "/usr/share/apt-listchanges/apt_listchanges.py", line 83, in read_apt_pipeline
    return map(lambda pkg: filenames[pkg], order)
  File "/usr/share/apt-listchanges/apt_listchanges.py", line 83, in <lambda>
KeyError: 'linux-image-server'
Setting up initramfs-tools (0.99ubuntu13.1) ...
update-initramfs: deferring update (trigger activated)
Setting up linux-image-3.2.0-37-generic (3.2.0-37.58) ...
Running depmod.
update-initramfs: deferring update (hook will be called later)
The link /initrd.img is a dangling linkto /boot/initrd.img-3.2.0-37-generic
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 3.2.0-37-generic /boot/vmlinuz-3.2.0-37-generic
update-initramfs: Generating /boot/initrd.img-3.2.0-37-generic
gzip: stdout: No space left on device
E: mkinitramfs failure cpio 141 gzip 1
update-initramfs: failed for /boot/initrd.img-3.2.0-37-generic with 1.
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/linux-image-3.2.0-37-generic.postinst line 1010.
dpkg: error processing linux-image-3.2.0-37-generic (--configure):
 subprocess installed post-installation script returned error exit status 2
dpkg: dependency problems prevent configuration of linux-image-server:
 linux-image-server depends on linux-image-3.2.0-37-generic; however:
  Package linux-image-3.2.0-37-generic is not configured yet.
dpkg: error processing linux-image-server (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of linux-server:
 linux-server depends on linux-image-server (= 3.2.0.37.44); however:
  Package linux-image-server is not configured yet.
 linux-server depends on linux-headers-server (= 3.2.0.37.44); however:
  Version of linux-headers-server on system is 3.2.0.37.45.
dpkg: error processing linux-server (--configure):
Processing triggers for initramfs-tools ...
update-initramfs: Generating /boot/initrd.img-3.2.0-36-generic
No apport report written because the error message indicates its a followup error from a previous failure.
update-initramfs: failed for /boot/initrd.img-3.2.0-36-generic with 1.
dpkg: error processing initramfs-tools (--configure):
 subprocess installed post-installation script returned error exit status 1
No apport report written because MaxReports is reached already
 linux-image-server
 linux-server
 initramfs-tools
I've tried a lot and can't get this working. I think I interrupted an install and it just screwed it all up. I've googled and tried various fixes.
EDIT (After cleaning my /boot folder) :
administrator@zlounes:/boot$ sudo apt-get -f install
  linux-server
  linux-server
1 upgraded, 0 newly installed, 0 to remove and 9 not upgraded.
1 not fully installed or removed.
Need to get 0 B/1,734 B of archives.
    main()
KeyError: 'linux-server'
  Version of linux-image-server on system is 3.2.0.37.45.
landroni
  • 6,011
zlounes
  • 523
5 Answers5
85
A good try to ensure that you system is in a good shape and not has problems with aborted installation is to invoke
  dpkg --configure -a
Ensure that the package list are updated and no problem is shown on:
 apt-get update
Optional you can remove all old data before the update with:
 find /var/lib/apt/lists -type f  |xargs rm -f >/dev/null \
Next step to resolve the problem is to remove the linux-server package for a while. This can be done because it has no real content and only introduce a dependency:
This package will always depend on the latest complete Linux kernel available for Server Equipment.
 dpkg --remove linux-server
After this step check that all current dependencies are installed:
apt-get install -f
If everything is o.k. you can now install linux-server again:
apt-get install linux-server
Postscriptum
linux-server is deprecated in 12.04. Also for server equipment the generic kernel is used. See apt-cache show linux-image-server
Package: linux-image-server...
Section: metapackages
Depends: linux-image-3.2.0-23-generic, linux-firmware
11
I am regularly having to clean out the /boot of my machines and usually being too full breaks the update - not sure what the ultimate solution is but the process I use seems to work:
Start off with a sudo su
Then go to /boot and do a ls -lSrh - the ones at the bottom are the biggest - rm enough of the older ones to clear up enough space.
Then try the following (as excerpted somewhat from above):
  1. sudo apt-get remove linux-server
  2. dpkg --configure -a
  3. apt-get update
  4. apt-get install -f
  5. apt-get autoremove
  6. dpkg --get-selections|grep 'linux-image*'|awk '{print $1}'|egrep -v "linux-image-$(uname -r)|linux-image-generic" |while read n;done
  7. apt-get install linux-image-server linux-server
  8. reboot
If anything fails, make a comment here and I will see what the issue might be.
I have seen this sort of thing work for the postgresql-9.1 package issues when using the pitti PPA as well.
One time when I ran the procedure I had a problem with grub. Doing a apt-get install --reinstall grub fixed it.
Thanks for the one liner goes to: http://ubuntuforums.org/showpost.php?p=12180959&postcount=7
Good luck!
I had a similar problem when using dpkg:
dpkg: dependency problems prevent configuration of rpi-imager:
 rpi-imager depends on qml-module-qtquick2; however:
 Package qml-module-qtquick2 is not installed.
Solution was to run sudo apt --fix-broken install
TSpark
  • 1,399
TL;DR Use dpkg --ignore-depends=...
I tried to install pulse-secure vpn client.
dpkg: regarding .../ps-pulse-ubuntu-debian.deb containing pulsesecure, pre-dependency problem:
 pulsesecure pre-depends on libcurl4
  libcurl4 is not installed.
dpkg: warning: ignoring pre-dependency problem! (Reading database ... 208790 files and directories currently installed.) Preparing to unpack .../ps-pulse-ubuntu-debian.deb ...
Solved with flag --ignore-depends=...
sudo dpkg --ignore-depends=libcurl4 -i /valo/pulse-secure-ubuntu-debian.deb
kyb
  • 161
It seems you run out of space. Clear some space and fix the package issues by:
sudo apt-get purge
sudo apt-get clean
sudo apt-get check
sudo apt-get install -f
sudo dpkg --configure -a
Then reinstall the packages again.
Source: Thread: Dpkg: Dependency problems - leaving unconfigured.
kenorb
  • 10,944
