33
I am trying to play around with some keyboard layouts in Ubuntu. Now there is a program called showkey which lets me see the keycode for any key pressed in the terminal. Is there any command to get the corresponding character for a specific keycode. For example when I type in
sudo showkey
//I get the response in the form
keycode num press/release
I was just wondering if I have the keycode, can I get the character mapping back so that I know which character I actually pressed?
Pablo Bianchi
  • 17,371
Run xev from a terminal. This will give you a new window.
Place your mouse pointer in this window, type some keys and watch for results in the terminal.
CoopDot
  • 636
17
In order to get a terminal print-out of all key codes and corresponding keys, run the following command in a terminal:
xmodmap -pk
It's not easy to view in a (small) terminal window, so if you want to save the output to a file, just add the command to let the terminal output be saved in a file (in your current working directory in the terminal):
xmodmap -pk > mykeyboard.txt
Full description of how to use xmodmap here.
5th
  • 317
