44
I installed Ubuntu on my PC. To log in, I use the username and password I created during installation. Does this mean I am a root user? If yes, then how do I become non-root? It looks like non-root user is more secure than admin user.
Eliah Kagan
  • 119,640
5 Answers5
85
You are an administrator, but not root. The root user can do anything. Administrators can perform actions as root, but ordinarily what administrators do is not done by root. That way, you have full control over your own system, but only when you choose to use it.
Ubuntu asks for your password when you try to do stuff as root, to make sure it's really you.
User Accounts: Human, and Otherwise
Real human users have user accounts to represent them. You created one such account when you installed Ubuntu. But not all user accounts represent real human users.
Real human users are granted (and denied) abilities through their user accounts. They must use their user accounts to use the system; therefore, their user accounts' abilities and limitations apply to them.
User accounts are also used to codify sets of abilities and limitations. Some user accounts--most, actually, unless you have many human users of the machine--exist so that certain programs or commands can be run with their identity, an identity with the right abilities and limitations for the job.
For example, the www-data user exists so that if you run a web server, it owns the data the server make accessible. No real human user has to be empowered to make unchecked changes to those data, and the web server doesn't have to be empowered to perform any action unnecessary for serving the web. Consequently, both the web data and the rest of the system are more secure against accidental or intentional breakage, than if the web server were run by some human user who would have all the powers of the web server (and whose powers the web server would possess).
The Most Important Non-Human User Account
The superuser, whose username is root, is a non-human user account with a very specific combination of abilities and limitations: all abilities, and no limitations.
root's allowed to do anything. There are still things root cannot do because the system itself cannot perform or make sense out of them. So root cannot kill a process that is in uninterruptible sleep, or make a rock too heavy to move, then move it.
Many important system processes, like init, run as root, and root is used for performing administrative tasks.
Can I log in as root?
It's possible to configure the root account so it's possible to log in with a password, but this is not enabled by default in Ubuntu. Instead, you can think of root as being like www-data, lp, nobody, and other non-human accounts. (Run cat /etc/passwd or getent passwd to see them all.)
Human users log in with their own user accounts, and then if some task is to be performed with another user account, they cause that task to be performed with that identity, without actually having logged in as that user.
It's possible to configure the other non-human users, like www-data, so one can log in as them, too. That's quite rare, though, whereas in some other Unix-like OSes it's common to log in as root in a terminal. The risks of running a whole graphical interface as root, combined with how many graphical programs are not designed to run as root and may not work properly, mean that you should never attempt to get a root-owned desktop session.
Please note that while logging in as root is disabled by default in Ubuntu, there are ways to get a root shell without authenticating as root, which produce a similar effect: the most common are sudo -s or -i, recovery mode and similar techniques. (Don't worry if you don't know what those things are.) This is not actually logging in: in recovery mode, you become root before any login would occur; with the sudo-based methods, you're just running a shell as root.
Administrators
In Ubuntu, administrators are the users who can do whatever they want as root, when they choose to do so.
System Settings, showing human user accounts including an administrator account.
System Settings > User Accounts. "Eliah Kagan" is an administrator, so he can do stuff as root, but he is not root.
I'm an administrator on my Ubuntu system. When I run programs, ordinarily they run as ek ("Eliah Kagan" is the full name that corresponds to the ek username.)
When I run AbiWord or LibreOffice, it runs as ek. When I run Firefox, Chromium, Empathy, or Pidgin, it runs as ek. The programs that run to provide the desktop interface run as ek.
However, I am an administrator, so if I need to perform an administrative task, I can do so.
sudo
On the command line, I would ordinarily use sudo to run a command as root:
sudo command...
This will prompt me for my password. (Not root's password; root does not have one.)
  • Because I am an administrator, I can perform actions as root. In the default configuration, I must enter my password to do this.
  • Users who are not administrators cannot perform actions as root, even by putting in their password. sudo commands will fail if the user running them is not an administrator.
Because administrators are perfectly ordinary users except for the ability to perform actions as root, running a command requiring root privileges will still fail, except when the command is run as root.
Screenshot illustrating the need for sudo: an administrator can only run certain commands successfully by doing so as <code>root</code>, which is usually done by prepending sudo (and a space) to the command.
Screenshot illustrating the need to use sudo to perform administrative tasks. (Based on "Sandwich" by Randall Munroe.)
sudo, Graphically
Graphical programs can run as root through graphical frontends for sudo, such as gksu/gksudo and kdesudo. For example, to run GParted as root I could run gksudo gparted. Then I would be prompted graphically for my password.
gksudo graphical password prompt
Since I'm prompted graphically, there doesn't have to be a terminal. This is one of the ways administrative tools are run as root.
Polkit
Polkit (once known as PolicyKit) is another way for administrators to do things as root. A program accesses a service that performs the action. Sometimes, the action is running a whole program; sometimes the action is more limited.
These days, many graphical system administration utilities are set up to use polkit by default, rather than to use sudo.
One example of such a utility is the Software Center. It takes full advantage of polkit, requiring the user to put in their password only when they want to do something that requires root privileges. (This is possible with sudo-based authentication also, but it is harder and uglier to accomplish.)
In the Software Center, I can find and read about an application; then I'm asked for my password when I want to install it.
Authenticating via polkit to install an application in the Ubuntu Software Center.
How polkit Is Different
Any graphical program can be run as root with gksudo and other graphical sudo frontends. (The program might not work very well, depending on whether or not it's designed to be used as root. But the command to start the program will be executed as root.)
While polkit is now more common than sudo GUI frontends as the way applications on Ubuntu perform actions as root behind the scenes, polki will only run a graphical application as root if there is a configuration file allowing it and indicating what actions may be performed.
Polkit, Non-Graphically
pkexec is the command used to run a program with polkit.
Like sudo, pkexec can run non-graphical commands. (And it does not require a configuration file defining the command's capabilities--it simply runs the command as root.)
pkexec command...
pkexec prompts for a password graphically, even if it is run from a Terminal (this is one of the ways its behavior is more similar to gksudo than to running straight sudo).
(If there is no GUI--for example, if you're logged in from a virtual console or text-only SSH session, or the GUI is not functioning properly--then pkexec will degrade gracefully and prompt for your password on the command line.)
Running a command in a terminal with pkexec.
Once authentication is performed successfully, the command runs in the terminal.
A command runs seamlessly as <code>root</code> after successfully polkit authentication.
Running Commands as Other Users Besides root
root is special because it gets to do anything that can be done. But it's a user account like any account, and the ways of running commands as root with sudo (directly or with a graphical frontend) or polkit can be modified slightly to run a command as any other user:
sudo -u username command...
gksudo -u username command...
pkexec --user username command...
What? You just type sudo first? How is that security?!
Running commands with sudo is sort of like invoking papal infalliblity.
When you run a command with sudo [invoke papal infallibility], Ubuntu [Catholic folks] tries hard to make sure you're really you [really the Pope].
Yes, I know papal infallibility (even when normative) is declarative; the parallel is not perfect.
Trying to do something as root with sudo (or polkit) is a big deal--Ubuntu is not just going to let that slide by like all the other times you run a program.
You are prompted for your password. (Then, that you have done so is remembered for a short time, so you don't have to constantly enter your password as you administer your system.)
Besides reminding you to be careful, this safeguards against two scenarios:
  • Someone uses your computer (or mobile device), maybe under the guise of checking their email or some similar innocuous purpose. Here, it's still possible for them to do some harm--for example, they could modify or delete your documents. However, they cannot administer the system, since they cannot put in your password.
  • Programs that aren't supposed to administer the system cannot do so, unless you enter your password. For example, if your web browser is compromised by a security bug and runs malicious code, it still cannot perform administrative tasks. It cannot create and delete users, modify programs installed as root (which includes anything installed by the package manager, such as LibreOffice), or alter the system at a deep level.
I've heard of su. What's that? Can I use that?
su authenticates as another user, and runs a command (or starts an interactive shell). It's possible to limit who is permitted to use su, but su authenticates with the target account's password, not the password of the user running.
For example, su username -c 'command...' runs command... as username, just like sudo -u username command....
But when you run a command as username with sudo, you enter your password. When you run a command as username with su, you enter username's password.
Since su performs authentication for the target user, with su you can only run commands as users whose accounts are enabled.
The root account (like www-data and nobody) is disabled by default. There is no password that will work to log in as root. So you cannot use su to run commands as root.
You can use su to run commands as another user who can log in (which typically includes all the user accounts on your system that represent human beings).
When logged in as a guest, you cannot use su at all.
Combining su and sudo
Someone who is not an administrator can even use su to run sudo as an administrator. (This is OK though, as they need the administrator's password to run commands as the administrator.) That is, a limited user can use su to run sudo to run a command as root. This can look like:
su username -c 'sudo command...'
(Running graphical programs this way requires special care.)
Wouldn't su be a more secure way to run commands as root?
Probably not.
What if a user shouldn't be allowed to act as root?
Make them a limited user instead of an administrator.
What if a program running as an administrator tries to sudo to root?
Unless you have reconfigured sudo to let it succeed without a password, it will fail.
Can't a program that shouldn't be run as root piggyback on a recent sudo command, so no password is required?
This would be very unlikely to succeed. These days, most operating systems (including Ubuntu) have sudo configured by default so that its timestamps apply only in a specific context.
For example, if I run sudo ... in one Terminal tab and authenticate successfully, sudo in another tab (or run by an unrelated GUI program, or that I run from a virtual console or SSH session) will still prompt for a password. Even if it's run immediately afterwards.
Doesn't a program running as user X have access to user X's password?
No.
If a malicious program is able to run as an administrator, can't it "listen in" to what's being typed when the administrator authenticates with sudo or polkit?
Potentially, yes. But then it could "listen in" to a password typed in for su.
If I tell someone my password—
Don't tell people your password.
What if someone has to know my password to do something on my behalf, but I don't want to let them administer the system?
Ideally, they should have a separate user account that lets them do what they need to do. For example, can share files between accounts, allowing multiple user to write to them, while still denying access to other users.
However, in a situation where a less-trusted person may be permitted to share your account, it should be a limited user account. You could make a separate account for this purpose (which makes sense--if it's an account for you and someone else who you want to have different capabilities, it should be a different account).
So, would the most secure thing be to disallow both sudo and su and make people log in as root, manually?
No, because there are serious disadvantages associated with letting people log in as root at all. Whenever possible, the smallest number of actions as possible should be undertaken as root. Even most acts relating directly to administering a system (e.g., looking at what users are configured, and reading logs) usually don't require root privileges.
Also, just as potentially a malicious program could watch what someone types when they run sudo or su, or create a fake sudo/su password prompt, potentially a malicious program could create a fake login screen, too.
What makes a user an administrator?
Group membership.
In Ubuntu 12.04 and later, administrators are members of the group called sudo.
In Ubuntu 11.10 and earlier, administrators are members of the group called admin.
When an Ubuntu system before 12.04 is upgraded to 12.04 or later, the admin group is kept for backward compatibility (and continues to confer administrative power to users in it), but the sudo group is used as well.
Limited User Accounts
Can I use a limited user account instead of an administrator account?
If you like, sure. Create a limited user account in System Settings > User Accounts, and log in as that user.
Can I make my administrator account a limited user account?
Yes, just remove it from the sudo and admin groups (see above).
But you should make sure there is at least one other administrator account, so you can administer your system. If there is not, then you'd have to boot to recovery mode or a live CD and make some user an administrator again. (This is similar to resetting a lost administrator password.)
Graphical tools for administering users and groups will usually keep you from creating a system with no administrators, or at least warn you. Command line tools typically will not (trusting that you know what you're doing).
Eliah Kagan
  • 119,640
No such thing as a dumb question ;)
I hope this clarifies things a bit:
In Ubuntu, two different types of user accounts may be made: standard accounts and administrator accounts. The difference between the two: a standard account is not allowed to make any important changes to your system by attaining root access, whereas an administrator account may use their password to make changes as the root user. The Root user itself is one of the many users that the system has created and that you do not normally see or notice, and you can't login as it (by default, anyway). If you are logged into an administrator type account, you can become this Root user with the sudo command in a terminal, and you are able to type in your password in order to install software, make system changes, etc. If you are logged in as a standard user, you are unable to do any of that.
Richard
  • 8,588
In All Linux systems To do any changes to the system we need to be authenticated as root user and as well as to apply all changes we need to be root user.
Normal users cant apply the changes system wide.This is the advantage with Linux as compare with the windows.
If any attack done then that will stem up to only that area in Linux/Unix system because to attack or to modify remaining areas It need root permissions but in Windows if one place got attacked means the whole system will get affected.
That's why only in many questions if any user placed for no prompt for root password, then we will warn him as this is not recommended under security circumstances and leave choice upto them.
If you want to turn into a root user ,sudo can help you.
sudo -i
If you would like launch application as root user then you can sudo .
sudo <app_name>
It always a Better to run the system as non-root user.
Raja G
  • 105,327
  • 107
  • 262
  • 331
The account created during installation is an administrator account.
In Ubuntu, root account has no password and as a consequence, you can not login as the root user. There are ways to circumvent this, but this is the default setting.
An Administrator account in Ubuntu means that the user is added to the group sudo, which makes the account eligible to gain previleges temporarily using the sudo command. PolicyKit can request privilege escalation by prompting 'Administrator' password. (You need to select a administrator user, and give that account's password.)
To confirm that these are true:
  • Open a terminal and attempt to update software package index. apt-get update is the command used to do it and this requires to be run as root. It works only when you either login as root, or execute it as root by using privilege escalations. An administrator can run sudo apt-get update by authenticating to the sudo mechanism which allows commands to be run as any user. A standard user will not be allowed to do this.
  • Open User accounts from System Settings and attempt to add a new user. The protection mechanism used there is the PolicyKit. Administrators will be allowed to authenticate and escalate privileges but standard users will be blocked. It requires an 'administrator' password to proceed.
Here is how you check if your account is administrator or not:
  • Open User accounts from System settings.
  • Select your user account in the left column.
  • You should see Administrator under the account name in both panes for administrator accounts and Standard for normal users.
Mahesh
  • 13,026
No.
the user you log in to Ubuntu with, is not the admin user (the admin user in Linux terminology is called root)
tomodachi
  • 15,370
