Possible Duplicate:
How to remove Ubuntu and put Windows back on?
i have ubuntu 12.10 with windows 7 installed on the same hard drive. ubuntu and windows are both installed on different partitions. I would like to remove ubuntu but I don't know which partition it is installed on to remove it. is there a partition manager in ubuntu to tell me which one it is on. because I want to keep my windows 7 but remove ubuntu. Thanks,
Your hard drive should be /dev/sda. If it is not, change to the hard drive number. type sudo fdisk /dev/sda Then type "p" to print table. Look for linux partition id (83) and swap. It will have a nuber after it, like sda6. To avoid any changes to your partition, make sure to tyoe "q" to exit. type "n" to show all option. It is self explanatory, but dangerous if you mess up.The NTFS is the windows partition.
