I am having some problems with my new laptop ASUS N76VM.
I have read up on the problem for the past couple of days, as it seem to be UEFI related. First, I tried to use the WUBI installer and since then it seems to have left some sort of boot setup behind.
At every boot, even after formatting the partition I created for my Ubuntu install, I get to choose between Windows 7 or Ubuntu, but no matter what, if I choose to boot in Ubuntu I get a /ubuntu/winboot/wubildr.mbr error.
The WUBI failed due to the UEFI problem, my BIOS holds no setup to disable the EFI protocol, so after a while i tried to install the x64 12.10 version from the LiveUSB stick, and chose to boot in UEFI USB mode. This installed just fine for the first time, but on boot I still get the choice between Ubuntu and Windows 7, but when booting into Ubuntu, I get the /ubuntu/winboot/wubildr.mbr error right away.
Since the /ubuntu/winboot/wubildr.mbr error shows up along with the choice of booting into Ubuntu. even when nothing should be installed except windows 7, I would think that the WUBI installer have messed something up in the bootloader.
Anyone has any good ideas?
null
  • 67
WUBI uses Windows bootloader that needs to be reverted back to its previous state using Windows tools.
When Ubuntu is installed using Live USB, it uses its own bootloader called GRUB.
Use How do I remove wubi? to fix Windows bootloader first.
Then you may have to fix GRUB using Boot Repair.
Look at Installing Ubuntu Alongside a Pre-Installed Windows with UEFI for detailed instructions on Ubuntu installation on UEFI computers with Windows 8. Some of it won't apply since you have Windows 7, but the rest may be useful.
user68186
  • 37,461
