I have a network which connects a couple of hosts.
I would like to be able to reach other hosts from one of them using the hostname.
I just discovered the ".local" domain, which is available through avahi and /etc/nsswitch.conf.
But it's not set up this way on my servers.
And I don't want to create an entry in my dns server.
Is there an other way to do so ?
Your /etc/nsswitch.conf should already have this for mDNS (avahi):
hosts: files mdns4_minimal [NOTFOUND=return] dns mdns4
Just install avahi-daemon on the machines you want talking to eachother, and you should be set to use HOSTNAME.local like this:
ssh yourmachine.local
- 73,717
- 17,823
An alternative is to add an entry in your /etc/hosts file:
gksudo gedit /etc/hosts
An entry takes the form 123.123.123.123 host.domain or just 123.123.123.123 host.
If you do that, you can now for example ssh host and it will connect to 123.123.123.123
- 39,359
- 768
I found another solution.
Using the file, /etc/dhccp3/dhcient.conf
There is a line starting like this, send host-name
This could be modified to
send host-name 'server1'
This solution look nice, but i don't know if the every machine which use the same dns will see my "server1" hostname.
Another bad side to this solution, i need to specify the hostname here and in the /etc/hosts
I just know that this file (/etc/dhcp3/dhclient.conf) is not a script, so i can't use a environnement variable to fill this line correctly.
- 343
if using avahi-daemon, you may need to copy ssh.services into /etc/avahi/services. On mine,
sudo cp /usr/share/doc/avahi-daemon/examples/ssh.service /etc/avahi/services/
