I have a desktop and a laptop PC. I can ssh from my laptop into my desktop by typing ssh desktop.local, but it doesn't work the other way round (I have to look up the ip address via ip a on desktop then type ssh 192.168.0.15 on laptop).
Sadly neither this nor this is helpful as both machines
  • have avahi-daemon installed
  • have the same line about mdns in /etc/nsswitch.conf
  • have the same send host-name = gethostname(); in /etc/dhcp/dhclient.conf
  • fail to find each other via host desktop or host desktop.local (!?)
  • mdns-scan finds both machines on both machines
I don't want to use the dirty hack of adding a line in /etc/hosts, especially because my laptop is sometimes on Ethernet and sometimes on WLAN, both having different IP addresses.
xjcl
  • 653
Avahi never works for me. Thus I am skeptical.
I think your router is allowing the desktop.local thing to work. Can you check? Did you set the desktop to receive port 22 on the router? People often do that unintentionally, since from outside, ssh requests go unanswered unless you direct them at a machine.
pauljohn32
  • 3,803
