I have two Ubuntu 18.04 and 20.x installs at home and trying to ssh between them, I can connect by Internal IP but not by hostname Setup:
Machine A: 192.x.x.115
Machine B: 192.x.x.125
both installs have ssh running and I can connect fine using internal IP.
From Machine B I would like to connect to Machine A using hostname or hostname.ddns.net
Here are things I have setup:
Machine A:
machineA> /etc/hosts
127.0.0.1    machineA.ddns.net machineA
192.x.x.115 machineA
machineA> /etc/hostname
machineA.ddns.net
machineA> /etc/resolv.conf
nameserver 127.0.0.53
options edns0 trust-ad
search hsd1.xx.isp.net
Machine B:
machineB> ssh user@192.x.x.115 # i.e machineA is successful
machineB> ssh -vvv user@machineA.ddns.net gives
Connecting to machineA.ddns.net [ISP assigned address] port 22.
ssh: connect to host machineA.ddns.net port 22: Connection timed out
ssh: Could not resolve hostname machineA: Name or service not known
SSH_from_external_to_machineA is successful
ssh user@machineA.ddns.net # is successful
commands tried on machineA:
machineA> sudo service ssh status # gives active(running)
machineA> sudo netstat -alnp | grep :22 # shows :22 with LISTEN
machineA> sudo iptables -A INPUT -p tcp --dport ssh -j ACCEPT
  1. I feel ISP is not blocking ssh from ssh since I can connect from external using machineA.ddns.net
  2. Router is allowing port 22 since I can connect using IP.
I feel hostname is not resolved correctly, please review and let me know if I am missing any additional steps.
Thanks,
Additional edits:
machineB> ping machineA_Hostname is successful
machineB> nslookup machineA.ddns.net is showing external IP as expected
machineB> ssh machineA # Could not resolve hostname: Name or service not known
machineB> ssh machineA.ddns.net attempts to connect to exact external IP that was reported by ping and 'Connection timed out'
You wanna ssh machine_B from machine_A via hostname, right?
so just put the internal IP of machine_B with a desired name (for calling machine_B) in machine_A
in order to do that, just edit /etc/hosts of machine_A and add something like below:
192.168.222.1 my_lovely_machine_B
now if you type:
ssh user@my_lovely_machine_B
that should work!
BUT if you don't want to bother yourself for hardcoding the internal IP address and make changes everytime (Because IP addresses may change) you can do two things.
First approach: The hard approach but the practical one: you need to run a DNS service such as BIND to get what you want
Second approach: The simple one but not good for every scenario (For you is OK): write a bash script for automation of setting static IP for machine_B and let it run on every startup. in this way you don't need to worry about IP changes and always your machine_B has the same IP.
To avoid hardcoding the internal IP address, setup avahi-daemon on Ubuntu for so you can reach hostname ubuntu.local from host OS.
sudo apt-get install avahi-daemon avahi-discover avahi-utils libnss-mdns mdns-scan
