I don't run gnome-panel normally. Most menubars work correctly. However, with wxMaxima and Audacity, they are not showing. When I start gnome-panel and add an appmenu, I can see the menus again.
Without panel:
With panel:
I get no relevant errors when I run from a terminal.
Why does this happen and what could I do to fix it? Against which package would I file this if this is a bug?
belacqua
  • 23,540
dv3500ea
  • 37,734
I have now reported this as a bug.
The work around is to edit ~/.bashrc by opening your home folder, pressing Ctrl+H and double clicking the file '.bashrc' to open it in the text editor. Add the following line to the file:
export UBUNTU_MENUPROXY=0
That only works for launching the program using the terminal. To fix the menu items, use the method outlined in the answer to Is it possible to make indicator-appmenu ignore a specific application?.
I eventually got it to work by creating a bash script to run the program with UBUNTU_MENUPROXY=0.
#!/bin/bash
/path/to/executable
and then editing the command in the application launcher to:
bash /path/to/bash/script
dv3500ea
  • 37,734
