Recently I minimal installed my OS, but got an unexpected error while setting my monitor resolution. It seems like a very old problem, but this time there is something else (I think).
- To install the desktop environment:
apt-get update,apt-get install xorg-core xserver-xorg-core gnome-core gdm3 - To install graphics drivers:
apt-get install build-essential nvidia-kernel-common linux-headers-$(uname -r),./NVIDIA-Linux-x86_64-304.64.run
With the above steps everything seems to go fine.
To set resolution :
cvt 1440 900,xrandr --newmode xxx,xrandr --addmode VGA-0 xxxThen I got this error:
X Error of failed request: BadMatch (invalid parameter attributes) Major opcode of failed request: 153 (RANDR). Minor opcode of failed request: 18 (RRAddOutputMode). Serial number of failed request: 29. Current serial number in output stream: 30
I don't know what information you need, but here is some:
- graphics card model: nVidia GT 630.
- graphics card's memory size: 512 M DDR5.
- monitor: Philips 190CW (1440x900, works well on Windows).
These are my settings in Windows (I haven't installed the monitor driver and Windows just recognizes it as 190g6.)
xrandr output:
Screen 0: minimum 8 x 8, current 1280 x 1024, maximum 16384 x 16384
DVI-I-0 disconnected (normal left inverted right x axis y axis)
VGA-0 connected 1280x1024+0+0 (normal left inverted right x axis y axis) 338mm x 270mm
1280x1024 60.0*+ 75.0
1024x768 75.0 70.1 60.0
800x600 75.0 72.2 60.3 56.2
640x480 75.0 72.8 59.9
DVI-I-1 disconnected (normal left inverted right x axis y axis)
HDMI-0 disconnected (normal left inverted right x axis y axis)
1440x900_60.00 (0x29f) 106.5MHz
h: width 1440 start 1528 end 1672 total 1904 skew 0 clock 55.9KHz
v: height 900 start 903 end 909 total 934 clock 59.9Hz
lshw -c video output:
*-display
description: VGA compatible controller
product: nVidia Corporation
vendor: nVidia Corporation
physical id: 0
bus info: pci@0000:05:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:16 memory:f6000000-f6ffffff memory:e0000000-efffffff(prefetchable) memory:f0000000-f1ffffff(prefetchable) ioport:d000(size=128) memory:f7000000-f707ffff(prefetchable)
xorg.conf:
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Unknown"
HorizSync 30.0 - 83.0
VertRefresh 55.0 - 75.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
SubSection "Display"
Depth 24
EndSubSection
EndSection
I tried to get edid:
sudo apt-get install read-edid
sudo get-edid | parse-edid
but got this error:
get-edid: get-edid version 2.0.0
Performing real mode VBE call
Interrupt 0x10 ax=0x4f00 bx=0x0 cx=0x0
Function supported
Call successful
VBE version 300
VBE string at 0x11100 "NVIDIA"
VBE/DDC service about to be called
Report DDC capabilities
Interrupt 0x10 ax=0x4f15 bx=0x0 cx=0x0
Function supported
Call successful
Monitor and video card combination does not support DDC1 transfers
Monitor and video card combination does not support DDC2 transfers
0 seconds per 128 byte EDID block transfer
Screen is not blanked during DDC transfer
Reading next EDID block
Read EDID
Interrupt 0x10 ax=0x4f15 bx=0x1 cx=0x0
Function supported
Call failed
The EDID data should not be trusted as the VBE call failed
Error: output block unchanged
I tried to force the resolution to 1440x900 by using nvidia-settings, after reboot, resolution changed to 1440x1024 (nvidia-settings added a line to xorg.conf: Option "metamodes" "1440x1024 +0+0").
The screen become horizon-scrollable like that:
I also tried to extract edid.bin (by using nvidia-settings) and add Option "CustomEDID" "DFP-1:/etc/X11/edid.bin" at Section "Device" to xorg.conf. thanks to the awesome post "Fixing Ugly DVI/HDMI Displays due to EDID bugs on nVidia drivers", but unfortunately it doesn't work either.
update: var/log/Xorg.0.log:
X.Org X Server 1.7.7
Release Date: 2010-05-04
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.0.0-1-amd64 x86_64 Debian
Current Operating System: Linux xx 2.6.32-5-amd64 #1 SMP Sun Sep 23 10:07:46 UTC 2012 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-5-amd64 root=UUID=df3ea9ad-faaf-4918-a213-5a673080e935 ro quiet
Build Date: 29 October 2011 06:58:14PM
xorg-server 2:1.7.7-14 (Julien Cristau <jcristau@debian.org>)
Current version of pixman: 0.16.4
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Tue Jan 8 23:09:08 2013
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(==) ServerLayout "Layout0"
(**) |-->Screen "Screen0" (0)
(**) | |-->Monitor "Monitor0"
(**) | |-->Device "Device0"
(**) |-->Input Device "Keyboard0"
(**) |-->Input Device "Mouse0"
(**) Option "Xinerama" "0"
(==) Automatically adding devices
(==) Automatically enabling devices
(WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
Entry deleted from font path.
(WW) `fonts.dir' not found (or not valid) in "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType".
(Run 'mkfontdir' on "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType").
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
(==) ModulePath set to "/usr/lib/xorg/modules"
(WW) AllowEmptyInput is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
(WW) Disabling Keyboard0
(WW) Disabling Mouse0
(II) Loader magic: 0x7c8a40
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 6.0
X.Org XInput driver : 7.0
X.Org Server Extension : 2.0
(++) using VT number 7
(--) PCI:(0:5:0:0) 10de:0f00:0000:0000 nVidia Corporation rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x0000d000/128, BIOS @ 0x????????/524288
(II) Open ACPI successful (/var/run/acpid.socket)
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.0.0
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension SELinux
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.0
(II) NVIDIA GLX Module 304.64 Tue Oct 30 11:18:32 PDT 2012
(II) Loading extension GLX
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: "dri2"
(II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.7.7, module version = 1.1.0
(II) Loading extension DRI2
(II) LoadModule: "nvidia"
(II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
(II) Module nvidia: vendor="NVIDIA Corporation"
Module class: X.Org Video Driver
(II) NVIDIA dlloader X Driver 304.64 Tue Oct 30 10:59:51 PDT 2012
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 05@00:00:0
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules/libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.4
(II) Loading sub module "wfb"
(II) LoadModule: "wfb"
(II) Loading /usr/lib/xorg/modules/libwfb.so
(II) Module wfb: vendor="X.Org Foundation"
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Module "ramdac" already built-in
() NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
() NVIDIA(0): Option "CustomEDID" "DFP-0:/home/teifi/edid.bin"
() Jan 08 23:09:09 NVIDIA(0): Enabling 2D acceleration
(II) Jan 08 23:09:10 NVIDIA(GPU-0): Display (Philips 190G6 (CRT-1)) does not support NVIDIA 3D
(II) Jan 08 23:09:10 NVIDIA(GPU-0): Vision stereo.
(II) Jan 08 23:09:10 NVIDIA(0): NVIDIA GPU GeForce GT 630 (GF108) at PCI:5:0:0 (GPU-0)
(--) Jan 08 23:09:10 NVIDIA(0): Memory: 1048576 kBytes
(--) Jan 08 23:09:10 NVIDIA(0): VideoBIOS: 70.08.aa.00.00
(II) Jan 08 23:09:10 NVIDIA(0): Detected PCI Express Link width: 16X
(--) Jan 08 23:09:10 NVIDIA(0): Interlaced video modes are supported on this GPU
(--) Jan 08 23:09:10 NVIDIA(0): Valid display device(s) on GeForce GT 630 at PCI:5:0:0
(--) Jan 08 23:09:10 NVIDIA(0): CRT-0
(--) Jan 08 23:09:10 NVIDIA(0): Philips 190G6 (CRT-1) (connected)
(--) Jan 08 23:09:10 NVIDIA(0): DFP-0
(--) Jan 08 23:09:10 NVIDIA(0): DFP-1
(--) Jan 08 23:09:10 NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
(--) Jan 08 23:09:10 NVIDIA(0): Philips 190G6 (CRT-1): 480.0 MHz maximum pixel clock
(--) Jan 08 23:09:10 NVIDIA(0): DFP-0: 330.0 MHz maximum pixel clock
(--) Jan 08 23:09:10 NVIDIA(0): DFP-0: Internal Single Link TMDS
(--) Jan 08 23:09:10 NVIDIA(0): DFP-1: 165.0 MHz maximum pixel clock
(--) Jan 08 23:09:10 NVIDIA(0): DFP-1: Internal Single Link TMDS
() Jan 08 23:09:10 NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
() Jan 08 23:09:10 NVIDIA(0): device Philips 190G6 (CRT-1) (Using EDID frequencies has
() Jan 08 23:09:10 NVIDIA(0): been enabled on all display devices.)
(WW) Jan 08 23:09:10 NVIDIA(0): No valid modes for "CRT-1:1440x900"; removing.
(WW) Jan 08 23:09:10 NVIDIA(0): No valid modes for "CRT-1:1280x800"; removing.
(II) Jan 08 23:09:10 NVIDIA(0): Validated MetaModes:
(II) Jan 08 23:09:10 NVIDIA(0): "CRT-1:1024x768"
(II) Jan 08 23:09:10 NVIDIA(0): "CRT-1:800x600"
(II) Jan 08 23:09:10 NVIDIA(0): Virtual screen size determined to be 1024 x 768
(--) Jan 08 23:09:10 NVIDIA(0): DPI set to (68, 65); computed from "UseEdidDpi" X config
(--) Jan 08 23:09:10 NVIDIA(0): option
(--) Depth 24 pixmap format is 32 bpp
(II) Jan 08 23:09:10 NVIDIA: Using 3072.00 MB of virtual memory for indirect memory
(II) Jan 08 23:09:10 NVIDIA: access.
(II) Jan 08 23:09:10 NVIDIA(0): Setting mode "CRT-1:1024x768"
(II) Loading extension NV-GLX
(==) NVIDIA(0): Disabling shared memory pixmaps
(==) NVIDIA(0): Backing store disabled
(==) NVIDIA(0): Silken mouse enabled
(==) NVIDIA(0): DPMS enabled
(II) Loading extension NV-CONTROL
(II) Loading extension XINERAMA
(WW) NVIDIA(0): Option "TwinView" is not used
(--) RandR disabled
(II) Initializing built-in extension Generic Event Extension
(II) Initializing built-in extension SHAPE
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension BIG-REQUESTS
(II) Initializing built-in extension SYNC
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-MISC
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
SELinux: Disabled on system, not enabling in X server
(II) Initializing extension GLX
(II) config/udev: Adding input device Power Button (/dev/input/event4)
() Power Button: Applying InputClass "evdev keyboard catchall"
(II) LoadModule: "evdev"
(II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
(II) Module evdev: vendor="X.Org Foundation"
compiled for 1.7.6.901, module version = 2.3.2
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 7.0
() Power Button: always reports core events
() Power Button: Device: "/dev/input/event4"
(II) Power Button: Found keys
(II) Power Button: Configuring as keyboard
(II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD)
() Option "xkb_rules" "evdev"
() Option "xkb_model" "pc105"
() Option "xkb_layout" "us"
(II) config/udev: Adding input device Power Button (/dev/input/event3)
() Power Button: Device: "/dev/input/event3"
(II) config/udev: Adding input device USB Optical Mouse (/dev/input/event2)
() USB Optical Mouse: Applying InputClass "evdev pointer catchall"
() USB Optical Mouse: always reports core events
() USB Optical Mouse: Device: "/dev/input/event2"
(II) USB Optical Mouse: Found 3 mouse buttons
(II) USB Optical Mouse: Found scroll wheel(s)
(II) USB Optical Mouse: Found relative axes
(II) USB Optical Mouse: Found x and y relative axes
(II) USB Optical Mouse: Configuring as mouse
() USB Optical Mouse: YAxisMapping: buttons 4 and 5
() USB Optical Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device "USB Optical Mouse" (type: MOUSE)
(II) USB Optical Mouse: initialized for relative axes.
(II) config/udev: Adding input device USB Optical Mouse (/dev/input/mouse1)
(II) No input driver/identifier specified (ignoring)
(II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event1)
() AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
() AT Translated Set 2 keyboard: always reports core events
() AT Translated Set 2 keyboard: Device: "/dev/input/event1"
(II) AT Translated Set 2 keyboard: Found keys
(II) AT Translated Set 2 keyboard: Configuring as keyboard
(II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD)
(II) config/udev: Adding input device PC Speaker (/dev/input/event5)
(II) config/udev: Adding input device Macintosh mouse button emulation (/dev/input/event0)
() Macintosh mouse button emulation: Applying InputClass "evdev pointer catchall"
() Macintosh mouse button emulation: always reports core events
() Macintosh mouse button emulation: Device: "/dev/input/event0"
(II) Macintosh mouse button emulation: Found 3 mouse buttons
(II) Macintosh mouse button emulation: Found relative axes
(II) Macintosh mouse button emulation: Found x and y relative axes
(II) Macintosh mouse button emulation: Configuring as mouse
() Macintosh mouse button emulation: YAxisMapping: buttons 4 and 5
() Macintosh mouse button emulation: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device "Macintosh mouse button emulation" (type: MOUSE)
(II) Macintosh mouse button emulation: initialized for relative axes.
(II) config/udev: Adding input device Macintosh mouse button emulation (/dev/input/mouse0)
(II) Jan 08 23:09:12 NVIDIA(GPU-0): Display (Philips 190G6 (CRT-1)) does not support NVIDIA 3D
(II) Jan 08 23:09:12 NVIDIA(GPU-0): Vision stereo.
() Jan 08 23:09:12 NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
() Jan 08 23:09:12 NVIDIA(0): device Philips 190G6 (CRT-1) (Using EDID frequencies has
() Jan 08 23:09:12 NVIDIA(0): been enabled on all display devices.)
(II) Jan 08 23:09:59 NVIDIA(GPU-0): Display (Philips 190G6 (CRT-1)) does not support NVIDIA 3D
(II) Jan 08 23:09:59 NVIDIA(GPU-0): Vision stereo.
() Jan 08 23:09:59 NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
() Jan 08 23:09:59 NVIDIA(0): device Philips 190G6 (CRT-1) (Using EDID frequencies has
() Jan 08 23:09:59 NVIDIA(0): been enabled on all display devices.)
(II) Jan 08 23:10:00 NVIDIA(GPU-0): Display (Philips 190G6 (CRT-1)) does not support NVIDIA 3D
(II) Jan 08 23:10:00 NVIDIA(GPU-0): Vision stereo.
() Jan 08 23:10:00 NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
() Jan 08 23:10:00 NVIDIA(0): device Philips 190G6 (CRT-1) (Using EDID frequencies has
() Jan 08 23:10:00 NVIDIA(0): been enabled on all display devices.)
(II) Jan 08 23:10:00 NVIDIA(0): Setting mode "VGA-0: nvidia-auto-select @1280x1024 +0+0"
(II) Jan 08 23:10:01 NVIDIA(GPU-0): Display (Philips 190G6 (CRT-1)) does not support NVIDIA 3D
(II) Jan 08 23:10:01 NVIDIA(GPU-0): Vision stereo.
() Jan 08 23:10:01 NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
() Jan 08 23:10:01 NVIDIA(0): device Philips 190G6 (CRT-1) (Using EDID frequencies has
(*) Jan 08 23:10:01 NVIDIA(0): been enabled on all display devices.)
Any help is greatly appreciated. Thank you
