Possible Duplicate:
How do I install Ubuntu from an USB drive / create a live USB-stick?
How can I create a bootable USB disk from a CD image?
I plug in my usb and turn my computer and then the copy rights come on the screen. It then says it cannot find the configuration file and I cannot do anything from there on. It is important to note I did use the universal usb thing and this appeared after I sued that and tried to boot the usb. Any help would be appreciated, thanks.
Try first plugging your USB into another computer and rename the folder "isolinux" to "syslinux" and the files "isolinux.bin" and "isolinux.cfg" in that folder to "syslinux.bin" and "syslinux.cfg" respectively. Then try booting with the USB again.
If that does not work, you will have to reformat your USB to FAT. You can do that using a tool like GParted ("sudo apt-get install gparted" in terminal). After that make the USB drive again and it should be fine.
Source: http://techie-buzz.com/how-to/syslinux-no-default-ui-error-fix.html
Zilvador
  • 417
