I am a newbie in linux and I don't know how to open the Ubuntu Software Center via Terminal!! Please help
I'm not sure why you'd want to, but
software-center
should do it. If you want to use command line to install a package then the correct way to do it would be
sudo apt-get install package-name
or
sudo apt-get remove package-name
to remove it. If you want a text based package manager then you could have a look at aptitude:
sudo aptitude
- 174,526
- 8,471
- 1
- 37
- 39
For Gnome Software replacing the old Canonical Ubuntu Software Centre <software-centre> (Preinstalled on Ubuntu 16.04 and later)
Open the terminal Ctrl+Alt+T
Then run;
sudo apt install gnome-software
gnome-software
For the the official gui software store snap-store;
First make sure snapd is installed and enabled
sudo apt update
sudo apt install snapd
Then install Snap Store
sudo snap install snap-store
snap-store
You can also replace the stable version with the preview version by running;
sudo snap remove snap-store && sudo snap install snap-store --channel=preview/edge
To revert back to the stable build of Snap Store run;
sudo snap remove snap-store && sudo snap install snap-store --stable
- 1,787
Times have changed, and with them, the answer to this question. In desktop Ubuntu 21.04, it is still possible to install Ubuntu Software Center. Since that is the program specified by the original question, the answer is that you run it from the command line, first by installing it via:
and then by running it via the following command, with or without sudo:
gnome-software
You can also run it by using Show Applications → Software icon (white suitcase with aqua circle).
Since Ubuntu Software Center is no longer installed by default, this question (if asked today) would refer, instead, to the Snap Store. If it was not present, it would reportedly be installed via:
In that case, the answer is that you run it via
snap-store
Or you could click on the suitcase icon, in this case an orange one bearing the letter A (short for "Snap" in Latin, perhaps), whose tool tip says (of course) "Ubuntu Software".
- 16,703
- 360
You simply enter the terminal (Ctrl+Alt+T) and write:
ubuntu-software
and press Enter.
- 417
For Ubuntu 22.04.3 use the command
snap-store
In case it does not load try this:
killall snap-store
sudo snap refresh
- 171
- 1
- 5
