first off: I am aware of this question
I want to open the "Ubuntu Software" I do have it installed, because I can see and open it from my menu-bar
picture of "Ubuntu Software" in menu-bar
I want to open it with the Terminal, because when I try to install "Dropbox" from Ubuntu Software, it just closes automatically. And now I want to see, if it works when I start it from the terminal.
I've tried all of these:
:~$ software-center
software-center: command not found
:~$ gnome-software Command 'gnome-software' not found, but can be installed with: sudo apt install gnome-software
:~$ ubuntu-software ubuntu-software: command not found
what else could I try?
I am using Ubuntu 20.04.2 LTS on 64-bit, with GNOME Version 3.36.8
eli44
  • 35
Try snap-store. That will launch the default Ubuntu software center, provided it is installed on your system (provided it is installed).
If it is not (anymore) installed, you can install it with the command sudo snap install snap-store.
vanadium
  • 97,564
