I am using Ubuntu 16.04. my Ubuntu software is not opening.I tried opening it through the terminal.When I type 'open Ubuntu software center', it shows 'Couldn't get a file descriptor referring to the console'. Please give me a solution.
Asked
Active
Viewed 555 times
Try type software-center on terminal. If the terminal says that it is not installed, install it by tipping sudo apt install software-center.
Then go on the icon of your ubuntu center and unlock from launcher and finally go to usr/share/application and drag the ubuntu software center on the launcher.
I have the same problem and in this way I solved it.
InstictV
- 61
