12
In Windows I use, beside the main Firefox installation, one or even two "Firefox clones" for different purposes (specifically oriented addons and configurations, light configuration without addons, configuration for a different user, etc).
For example, in Windows, Pale Moon, Cometbird and Wyzo are FF clones (but they do not have Linux support). Basically, Flock browser would also qualify, and it had support for Linux: but it was discontinued.
A "Firefox clone" is a term that I adopted from the use in Windows, the meaning of which includes these two elements:
(1). is a browser that is identical (based on Mozilla Firefox) or very similar and has large/full support for FF extensions, configuration, profiles. = can use FF extensions etc.
(2). runs independently from Firefox, can be opened at the same time with Firefox = does not share FF extensions etc.]
(That is, a FF clone would be to Firefox what Google Chrome and SRWare Iron are to Chromium - almost identical, but able to run separately in parallel.)
[Seamonkey, has support for Linux, but (although it can use a lot of FF extensions): themes are not working, the interface is in general different and rather primitive. It has the merit of keeping the pace with FF 4+ (in contrast with Swiftweasel, for example.)]
Are there such more browsers available in Ubuntu?
(As for comments asking why I "really" need these "clones", I am just used to doing that, I like two separate Firefox-like browsers: isn't pleasure, just like curiosity, a good reason for an action?)
Edit after using multiple accounts: after testing for a while this solution that has prevailed here (was most up-voted) of using multiple accounts I have to say that it may involve certain problems in cases where other separate customizations/advanced uses are implemented. (For example, using scripts to search internet for selected text may open new unwanted profiles instead of the default one; or using firefox "openwith" addon to try and open a link with a new ff profile would give a report that the profile is not accessible.) A complete separate browser for a parallel use may be in such cases more useful. (In this respect, Seamonkey deserves to be taken into account. )
Edit considering the definitive answer: although answers proposing the use of multiple accounts were most voted, I will prefer an answer that proposes a separate browser, for two reasons: 1. that is what the question asks for in the first place, and 2. multiple accounts may involve some problems, like those mentioned above.
7 Answers7
27
The best Firefox-clone would be a new separate instance of Firefox running with a separate profile. That could be launched from a separate shortcut/launcher or from within Firefox (see the addon at the end).
Firefox allows the creation of separate profiles, they are easy to setup and you may use as many sets of addons and configurations as you wish.
To start the profile manager, open the terminal and type firefox -ProfileManager -no-remote
Then the profile manager comes up, click on create profile, and then name your profile, for example set1. You can also point another location for the profile folder. By default, the profile folder is located at /home/user/.mozilla/firefox/ and is named with a string of 8 random characters, followed by the name you gave it. You have to do Ctrl + H while in the home directory, to be able to see .mozilla folder.
Instead of rebuilding an existing profile you have already built on Windows, you may go to the profile folder of your Windows Firefox, copy all contents and then paste them on your recently created profile folder in Ubuntu's Firefox. As detailed here, on Windows, the default location of Firefox profile folder is **%APPDATA%\Mozilla\Firefox\Profiles**
Then again, start profile manager, select your profile and you will be using it just the same.
Repeat the process for every profile you wish to create.
Now to be able to start each profile from a single shortcut and use more than one profile simultaneously, as detailed in this question, create a new text file on your desktop, name it set1.desktop.
Copy this to the text file
[Desktop Entry]
Type=Application
Name=Firefox set1
Comment=My primary profile
Exec=firefox -Profile /home/user/.mozilla/firefox/xxxxxxxx.set1 -no-remote
Path=/home/user
Icon=/my/icon/location
Terminal=false
StartupNotify=false
Replace user and set1 with your username and profile name, respectively, and place the 8 random characters attributed to this profile.
Note that you can set up a customized icon for this profile, this is helpful for diferentiation purposes, just point its location on the Icon line, for example /home/user/images/firefoxicon.png
After that, save the changes, right click on the text file, make sure its name has the .desktop and on the permissions tab, allow it to run as an application.
Now you have a shortcut to start this Firefox profile. When launched, you can right click on this icon in the Unity launcher and lock it there, so it is always accessible. You may move the shortcut somewhere else in your home folder too, it doesn't have to be on the desktop.
Repeat the previous steps for each profile you have created before, and then, with just a double-click, you will have one or more Firefox profiles started.
It will require some work to set up, depending on how many profiles you wish, but after that, it really is almost like you had several Firefox instances installed.
The source of this answer is this one given by Mik to a separate question: How to create shortcuts to different Firefox profiles.
To switch profiles within Firefox with one click, see this addon.
11
Instead of using clones, you may use different profiles with Firefox.
Just press Alt + F2 and type firefox -profilemanager. Create different profiles as necessary and run them simultaneously if needed.
To run Firefox with a different profile you would type firefox -P PROFILENAME -no-remote
You may even create different .desktop files with the command-line options added to launch them easily. Simply copy the /usr/share/applications/firefox.desktop file to ~/.local/share/applications rename it and edit the exec line adding the -P PROFILENAME -no-remote.
To Do
  • 15,833
Now, Pale Moon is available for Linux. More on this, here.
In addition to the previously mentioned Iceweasel, there's also IceCat, Swiftfox and Swiftweasel.
(If you're feeling adventurous, there's also Conkeror, which is basically Firefox for people who hate using a mouse.)
Flock was discontinued.
Finally, if you want, literally another Firefox installation, you could just download the binary package and install it to another location.
Edit for setting as the definitive answer:
As indicated, the intended browsers should satisfy two conditions: (1) support Firefox addons and plugins, and (2) run separately from Firefox, without interference.
Icecat fully satisfies these demands. More details in this complementary answer.
Swiftweasel also satisfies the demands, but in relation with an outdated version of Firefox.
Seamonkey has a limited support for themes but the most important extensions are supported (more here.)
For details and updates keep an eye on this complementary answer.
Dan Jones
  • 1,079
Pale Moon, mentioned in the question, is my favourite in Windows and it was in fact the main reference when asking for a similar application for Ubuntu: now, it is available for Linux.
The website:
General info on the project:
An article on Pale Moon, here.
Pale Moon in Linux fully supports Firefox themes and addons:
What I was really asking in the question was browsers that satisfy the following two conditions:**
1. To be a 'double' of Firefox, that is to be identical, or very similar, so as to have all support for Firefox extensions, plugins, themes.
2. To be able to run side-by-side with Firefox but without any interference (regarding profiles, extensions etc).
Icecat (first mentioned in this answer)
sudo add-apt-repository ppa:gnuzilla-team/ppa && sudo apt-get update && sudo apt-get install icecat -y
Full support for all Firefox extensions, plugins and so on. Operates completely separate from Firefox.
Swiftweasel kept the pace with Firefox only up to version 3.5.6 (here - just like Seamonkey, it runs 'portable').
Gmail is displayed in html version only.
Last update - 2010.
But for the rest seems to run smoothly, a lot of main extensions ans themes are still supported and it also seems lighter than last Firefox: but this could be misleading, as it takes less RAM but sometimes more CPU resources.
Considering the other browsers mentioned in the linked answer: Swiftfox displays version 3.6.1, the forum link and download links are not working. I was not able to install it (in the past I did, but it was not working separately from firefox).
It is a bit tricky to install Iceweasel in Ubuntu and this browser will "take over" ("compete with") the main Firefox installation (see this answer).
Flock browser is dead. (Only a mobile version proposed.)
So, one solution is: Icecat.
Another solution is Nightly version of Firefox - as specified in this other answer.
Also, Seamonkey satisfies in fact those conditions, in the sense that most important addons work, or have separate support from places like mozdev.org. More here.
If you really want them to be identical, but still have at least some difference, you may want to use the Firefox Nightly build.
Since the only Linux downloads on the site are annoying source-code tarballs, you will probably want to install via the repository:
sudo add-apt-repository ppa:ubuntu-mozilla-daily/ppa
sudo apt-get update
sudo apt-get install firefox-trunk
Then, just check your programs list for "Nightly." It will be called "Nightly Web Browser," but that one is Firefox Nightly.
It runs with a completely separate profile, and will have some subtle differences from the stable, tested Mozilla Firefox.
This should be exactly what you're looking for!
JamesTheAwesomeDude
  • 1,986
  • 42
I've found Waterfox very helpful. It's updated and supports Firefox's add-ons, it also doesn't restrict the addons you can install and keeps a different profile from the original Firefox.
Hosein
Yet another possibility (not necessarily the best) is to run Tor Project's portable Firefox from the Tor Browser Bundle.
Some arguments in favor are:
  1. It's Firefox ESR with some modifications.
  2. Completely portable (source of quote), meaning its user profile is separated from any other Firefox or similar installed on the system:
    This package requires no installation. Just extract it and run.
  3. No hacking other than extracting the files and double-clicking on either start-tor-browser (you might choose to stop Tor services) or directly run-mozilla.sh under the App/Firefox folder. Naturally, it can be added to the Dash too.
To still benefit from the protection provided by the Tor software, you can simply make a copy of the Firefox folder somewhere else.
This way, you keep the original Firefox distributed as part of the Tor Browser Bundle (and use it whenever you want anonymity on the internet), and you can run and configure as you like the copy of the Firefox.
This is because several extensions and plugins are not compatible with the anonymity intended when using the Tor software.
I wouldn't claim this is the best answer, but I think it clearly fits the requirements on your original question.
carnendil
  • 5,529
