50
How to log CPU load to a file in order to investigate a problem?
Jorge Castro
  • 73,717
tommyk
  • 4,556
6 Answers6
67
This works very well:
 while true; do uptime >> uptime.log; sleep 1; done
  • This will log your cpu load every second and append it to a file uptime.log.
    You can then import this file into Gnumeric or the OpenOffice spreadsheet to create a nice graph (select 'separated by spaces' on import).
As Scaine noticed, this won't be enough to diagnose the problem. So, additionally, run this (or use his answer for this part):
while true; do (echo "%CPU %MEM ARGS $(date)" && ps -e -o pcpu,pmem,args --sort=pcpu | cut -d" " -f1-5 | tail) >> ps.log; sleep 5; done
  • This will append the Top 10 most CPU hungry processes to a file ps.log every five seconds.
    Note that this is not the full boat-load of information top would give you. This is just the top 10, and just their CPU Usage, Memory Usage and the first argument (i.e. their command without further arguments, as in /usr/bin/firefox)
After you've used a Spreadsheet to create a graph to see when your CPU load went through the roof, you can then search this file for the nearest time to see what process has caused it.
This is what those files will look like:
uptime.log
~$ cat uptime.log
 22:57:42 up 1 day,  4:38,  4 users,  load average: 1.00, 1.26, 1.21
 22:57:43 up 1 day,  4:38,  4 users,  load average: 0.92, 1.24, 1.21
 22:57:44 up 1 day,  4:38,  4 users,  load average: 0.92, 1.24, 1.21
 22:57:45 up 1 day,  4:38,  4 users,  load average: 0.92, 1.24, 1.21
ps.log
%CPU %MEM ARGS Mo 17. Jan 23:09:47 CET 2011
 0.7  0.9 /usr/bin/compiz
 0.8  0.5 /usr/lib/gnome-panel/clock-applet
 1.1  1.7 /opt/google/chrome/chrome
 1.2  0.3 /usr/bin/pulseaudio
 1.8  4.0 /opt/google/chrome/chrome
 2.6  1.5 /opt/google/chrome/chrome
 2.6  3.2 /usr/bin/google-chrome
 3.6  2.6 /opt/google/chrome/chrome
 4.9  1.5 /usr/bin/X
 5.7  1.6 /opt/google/chrome/chrome
%CPU %MEM ARGS Mo 17. Jan 23:09:48 CET 2011
 1.0  1.7 /opt/google/chrome/chrome
 4.9  1.5 /usr/bin/X
16
You can run the top command in batch mode by using the -b option, then dump that to a file.
On start up of your PC, open a terminal, run
top -b > ~/cpu.txt
Then when your PC freezes, simply open the (probably huge) text file and check the last entry for some detail on what was running just before the crash. In the fact the file will be so stupidly large that you're better off running a tail -250 ~/cpu.txt instead.
Also check your /var/log/kern.log in case your issue is hardware related (unlikely if this is only happening after an upgrade, but worth checking nonetheless).
Scaine
  • 11,229
I found a great answer by Christopher to this question on Unix and Linux that uses top:
top -n 1 -b > top.out
This will give you 1 iteration of top then stop, and then push it to a file.
Zanna
  • 72,312
Luay
  • 71
For those who need to run this command after your putty ( SSH client ) session end. you can use command screen ( or install it using apt-get )
Mostafa
  • 121
I`ve got an script for get the process load, with rotating logs:
#!/bin/bash
MaxFileSize=204800
DaysToKeep=7
echo -e "\n Fecha:"`date` >> /var/log/ps.log
echo -e "\n Uptime: "`uptime` >> /var/log/ps.log
ps -e -o pcpu,pmem,args --sort=pcpu | tail >> /var/log/ps.log
#Get size in bytes**
file_size=`du -b /var/log/ps.log | tr -s '\t' ' ' | cut -d' ' -f1`
if [ $file_size -gt $MaxFileSize ];then
    timestamp=`date +%s`
    mv /var/log/ps.log /var/log/ps.log.$timestamp
    gzip /var/log/ps.log.$timestamp
    touch /var/log/ps.log
    # remove old files
    find /var/log -name "ps.log.*" -type f -mtime +$DaysToKeep -delete
fi
My original source can be browsed here
Here's a logging script I wrote and use: cpu_logger.py. It logs continuously to a set of rotating log files. It allows me to write reports to Google like this: Chrome Google Meet CPU usage is still too high (see plots and CPU usage during Google Meet with my camera ON vs OFF).
Run it at a high priority with the soft real-time Round Robin (rr) scheduler so it can log even when your system freezes:
sudo chrt -rr 1 path/to/eRCaGuy_dotfiles/useful_scripts/cpu_logger.py
View the output live with:
less -N --follow-name +F ~/cpu_log.log
Here is some sample output for only 2 log periods (at logging loop iterations 2 and 3):
2022-12-13__11:15:54, INFO, ======================== START of loop count 2 =============================
Output from psutil: ===> Overall CPU usage: 6.74% <=== Individual CPUs: 7.10%, 5.40%, 6.60%, 8.40%, 6.80%, 8.10%, 6.10%, 5.40%
Output from ps: 1/10) 9.60% cmd: /opt/google/chrome/chrome --type=gpu-process --enable-logging --v=1 --crashpad-handler-pid=4597 --enable-crash-reporter=, --change-stack-guard-on-fork=enable --gpu-preferences=WAAAAAAAAAAgAAAIAAAAAAAAAAAAAAAAAABgAAAAAAA4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACAAAAAAAAAAIAAAAAAAAAABAAAAAAAAAAgAAAAAAAAACAAAAAAAAAAIAAAAAAAAAA== --enable-logging --v=1 --shared-files --field-trial-handle=0,i,10345357081311849081,14286725297577549623,131072 2/10) 9.60% cmd: /opt/google/chrome/chrome --enable-logging --v=1 3/10) 7.10% cmd: /usr/lib/xorg/Xorg vt2 -displayfd 3 -auth /run/user/46153590/gdm/Xauthority -background none -noreset -keeptty -verbose 3 4/10) 3.60% cmd: /usr/bin/gnome-shell 5/10) 2.80% cmd: /opt/google/chrome/chrome --type=renderer --crashpad-handler-pid=4597 --enable-crash-reporter=, --change-stack-guard-on-fork=enable --enable-logging --v=1 --lang=en-US --num-raster-threads=4 --enable-main-frame-before-activation --renderer-client-id=2676 --time-ticks-at-unix-epoch=-1670887632073225 --launch-time-ticks=66582148957 --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,10345357081311849081,14286725297577549623,131072 6/10) 2.70% cmd: /opt/google/chrome/chrome --type=utility --utility-sub-type=network.mojom.NetworkService --lang=en-US --service-sandbox-type=none --enable-logging --v=1 --crashpad-handler-pid=4597 --enable-crash-reporter=, --change-stack-guard-on-fork=enable --enable-logging --v=1 --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,10345357081311849081,14286725297577549623,131072 7/10) 2.70% cmd: /opt/google/chrome/chrome --type=renderer --crashpad-handler-pid=4597 --enable-crash-reporter=, --extension-process --change-stack-guard-on-fork=enable --enable-logging --v=1 --lang=en-US --num-raster-threads=4 --enable-main-frame-before-activation --renderer-client-id=6 --time-ticks-at-unix-epoch=-1670887632073225 --launch-time-ticks=84780073 --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,10345357081311849081,14286725297577549623,131072 8/10) 2.70% cmd: /opt/google/chrome/chrome --type=renderer --crashpad-handler-pid=4597 --enable-crash-reporter=, --change-stack-guard-on-fork=enable --enable-logging --v=1 --lang=en-US --num-raster-threads=4 --enable-main-frame-before-activation --renderer-client-id=251 --time-ticks-at-unix-epoch=-1670887632073225 --launch-time-ticks=197275785 --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,10345357081311849081,14286725297577549623,131072 9/10) 2.30% cmd: /opt/google/chrome/chrome --type=renderer --crashpad-handler-pid=4597 --enable-crash-reporter=, --change-stack-guard-on-fork=enable --enable-logging --v=1 --lang=en-US --num-raster-threads=4 --enable-main-frame-before-activation --renderer-client-id=92 --time-ticks-at-unix-epoch=-1670887632073225 --launch-time-ticks=134655739 --shared-files=v8_context_snapshot_data:100 --field-trial-handle=0,i,10345357081311849081,14286725297577549623,131072 10/10) 1.80% cmd: /home/gabriel.staples/.p2/pool/plugins/org.eclipse.justj.openjdk.hotspot.jre.full.linux.x86_64_19.0.1.v20221102-1007/jre/bin/java --add-opens=java.base/java.io=ALL-UNNAMED --add-opens=java.base/sun.nio.ch=ALL-UNNAMED --add-opens=java.base/java.net=ALL-UNNAMED --add-opens=java.base/sun.security.ssl=ALL-UNNAMED -Dosgi.requiredJavaVersion=17 -Dosgi.instance.area.default=@user.home/eclipse-workspace -Dsun.java.command=Eclipse -XX:+UseG1GC -XX:+UseStringDeduplication --add-modules=ALL-SYSTEM -Dosgi.requiredJavaVersion=11 -Dosgi.dataAreaRequiresExplicitInit=true -Dorg.eclipse.swt.graphics.Resource.reportNonDisposed=true -Xms1024m -Xmx12288m --add-modules=ALL-SYSTEM -Declipse.p2.max.threads=4 -Doomph.update.url=https://download.eclipse.org/oomph/updates/milestone/latest -Doomph.redirection.index.redirection=index:/->http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/ --add-opens=java.base/java.lang=ALL-UNNAMED -Djava.security.manager=allow -jar /home/gabriel.staples/eclipse/cpp-2022-09/eclipse//plugins/org.eclipse.equinox.launcher_1.6.400.v20210924-0641.jar -os linux -ws gtk -arch x86_64 -showsplash /home/gabriel.staples/.p2/pool/plugins/org.eclipse.epp.package.common_4.25.0.20220908-1200/splash.bmp -launcher /home/gabriel.staples/eclipse/cpp-2022-09/eclipse/eclipse -name Eclipse --launcher.library /home/gabriel.staples/.p2/pool/plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.2.600.v20220720-1916/eclipse_11701.so -startup /home/gabriel.staples/eclipse/cpp-2022-09/eclipse//plugins/org.eclipse.equinox.launcher_1.6.400.v20210924-0641.jar --launcher.appendVmargs -exitdata c8003 -product org.eclipse.epp.package.cpp.product -vm /home/gabriel.staples/.p2/pool/plugins/org.eclipse.justj.openjdk.hotspot.jre.full.linux.x86_64_19.0.1.v20221102-1007/jre/bin/java -vmargs --add-opens=java.base/java.io=ALL-UNNAMED --add-opens=java.base/sun.nio.ch=ALL-UNNAMED --add-opens=java.base/java.net=ALL-UNNAMED --add-opens=java.base/sun.security.ssl=ALL-UNNAMED -Dosgi.requiredJavaVersion=17 -Dosgi.instance.area.default=@user.home/eclipse-workspace -Dsun.java.command=Eclipse -XX:+UseG1GC -XX:+UseStringDeduplication --add-modules=ALL-SYSTEM -Dosgi.requiredJavaVersion=11 -Dosgi.dataAreaRequiresExplicitInit=true -Dorg.eclipse.swt.graphics.Resource.reportNonDisposed=true -Xms1024m -Xmx12288m --add-modules=ALL-SYSTEM -Declipse.p2.max.threads=4 -Doomph.update.url=https://download.eclipse.org/oomph/updates/milestone/latest -Doomph.redirection.index.redirection=index:/->http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/ --add-opens=java.base/java.lang=ALL-UNNAMED -Djava.security.manager=allow -jar /home/gabriel.staples/eclipse/cpp-2022-09/eclipse//plugins/org.eclipse.equinox.launcher_1.6.400.v20210924-0641.jar
Output from top:
top - 11:15:58 up 18:48, 1 user, load average: 1.22, 0.97, 1.00 Tasks: 553 total, 1 running, 463 sleeping, 0 stopped, 0 zombie %Cpu(s): 7.0 us, 1.5 sy, 0.0 ni, 91.0 id, 0.3 wa, 0.0 hi, 0.2 si, 0.0 st KiB Mem : 32653848 total, 1021180 free, 17097652 used, 14535016 buff/cache KiB Swap: 67108860 total, 67037692 free, 71168 used. 11074732 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 18471 root -2 0 54124 5616 4340 R 23.5 0.0 0:00.05 top 4924 gabriel+ 20 0 1.104t 154220 96964 S 11.8 0.5 30:31.56 chrome 3861 gabriel+ 20 0 1665116 461364 419480 S 5.9 1.4 80:44.29 Xorg 4663 gabriel+ 20 0 32.845g 343052 172952 S 5.9 1.1 108:34.41 chrome 4667 gabriel+ 20 0 32.531g 159260 95968 S 5.9 0.5 31:32.68 chrome 10621 gabriel+ 20 0 1.104t 622144 111376 S 5.9 1.9 30:56.39 chrome 1 root 20 0 226380 8948 5576 S 0.0 0.0 1:08.29 systemd 2 root 20 0 0 0 0 S 0.0 0.0 0:00.13 kthreadd 6 root 0 -20 0 0 0 I 0.0 0.0 0:01.80 kworker/0:+ 7 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 mm_percpu_+ 8 root 20 0 0 0 0 S 0.0 0.0 0:04.77 ksoftirqd/0 9 root 20 0 0 0 0 I 0.0 0.0 1:43.23 rcu_sched 10 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_bh 11 root rt 0 0 0 0 S 0.0 0.0 0:00.11 migration/0 12 root rt 0 0 0 0 S 0.0 0.0 0:00.22 watchdog/0 13 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/0 14 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/1 15 root rt 0 0 0 0 S 0.0 0.0 0:00.20 watchdog/1 16 root rt 0 0 0 0 S 0.0 0.0 0:00.07 migration/1 17 root 20 0 0 0 0 S 0.0 0.0 0:01.78 ksoftirqd/1 19 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/1:+ 20 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/2 21 root rt 0 0 0 0 S 0.0 0.0 0:00.19 watchdog/2 22 root rt 0 0 0 0 S 0.0 0.0 0:00.08 migration/2 23 root 20 0 0 0 0 S 0.0 0.0 0:01.87 ksoftirqd/2 25 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/2:+ 26 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/3 27 root rt 0 0 0 0 S 0.0 0.0 0:00.22 watchdog/3 28 root rt 0 0 0 0 S 0.0 0.0 0:00.06 migration/3 29 root 20 0 0 0 0 S 0.0 0.0 0:08.57 ksoftirqd/3 31 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/3:+ 32 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/4 33 root rt 0 0 0 0 S 0.0 0.0 0:00.20 watchdog/4 34 root rt 0 0 0 0 S 0.0 0.0 0:00.08 migration/4 35 root 20 0 0 0 0 S 0.0 0.0 0:01.34 ksoftirqd/4 37 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/4:+ 38 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/5 39 root rt 0 0 0 0 S 0.0 0.0 0:00.19 watchdog/5 40 root rt 0 0 0 0 S 0.0 0.0 0:00.07 migration/5 41 root 20 0 0 0 0 S 0.0 0.0 0:01.02 ksoftirqd/5 43 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/5:+ 44 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/6 45 root rt 0 0 0 0 S 0.0 0.0 0:00.19 watchdog/6
2022-12-13__11:15:58, INFO, ======================== START of loop count 3 =============================
Output from psutil: ===> Overall CPU usage: 9.01% <=== Individual CPUs: 10.70%, 7.70%, 8.70%, 9.40%, 8.10%, 10.90%, 7.60%, 9.00%
Output from top:
top - 11:16:02 up 18:48, 1 user, load average: 1.20, 0.97, 1.00 Tasks: 553 total, 1 running, 463 sleeping, 0 stopped, 0 zombie %Cpu(s): 7.0 us, 1.5 sy, 0.0 ni, 91.0 id, 0.3 wa, 0.0 hi, 0.2 si, 0.0 st KiB Mem : 32653848 total, 992152 free, 17102156 used, 14559540 buff/cache KiB Swap: 67108860 total, 67037692 free, 71168 used. 11045748 avail Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 18480 root -2 0 54124 5712 4440 R 29.4 0.0 0:00.05 top 4663 gabriel+ 20 0 32.848g 343408 173340 S 11.8 1.1 108:34.77 chrome 3861 gabriel+ 20 0 1664572 461292 419408 S 5.9 1.4 80:45.05 Xorg 7377 gabriel+ 20 0 1.108t 420352 117716 S 5.9 1.3 26:53.60 chrome 1 root 20 0 226380 8948 5576 S 0.0 0.0 1:08.30 systemd 2 root 20 0 0 0 0 S 0.0 0.0 0:00.13 kthreadd 6 root 0 -20 0 0 0 I 0.0 0.0 0:01.80 kworker/0:+ 7 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 mm_percpu_+ 8 root 20 0 0 0 0 S 0.0 0.0 0:04.77 ksoftirqd/0 9 root 20 0 0 0 0 I 0.0 0.0 1:43.24 rcu_sched 10 root 20 0 0 0 0 I 0.0 0.0 0:00.00 rcu_bh 11 root rt 0 0 0 0 S 0.0 0.0 0:00.11 migration/0 12 root rt 0 0 0 0 S 0.0 0.0 0:00.22 watchdog/0 13 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/0 14 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/1 15 root rt 0 0 0 0 S 0.0 0.0 0:00.20 watchdog/1 16 root rt 0 0 0 0 S 0.0 0.0 0:00.07 migration/1 17 root 20 0 0 0 0 S 0.0 0.0 0:01.78 ksoftirqd/1 19 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/1:+ 20 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/2 21 root rt 0 0 0 0 S 0.0 0.0 0:00.19 watchdog/2 22 root rt 0 0 0 0 S 0.0 0.0 0:00.08 migration/2 23 root 20 0 0 0 0 S 0.0 0.0 0:01.87 ksoftirqd/2 25 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/2:+ 26 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/3 27 root rt 0 0 0 0 S 0.0 0.0 0:00.22 watchdog/3 28 root rt 0 0 0 0 S 0.0 0.0 0:00.06 migration/3 29 root 20 0 0 0 0 S 0.0 0.0 0:08.57 ksoftirqd/3 31 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/3:+ 32 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/4 33 root rt 0 0 0 0 S 0.0 0.0 0:00.20 watchdog/4 34 root rt 0 0 0 0 S 0.0 0.0 0:00.08 migration/4 35 root 20 0 0 0 0 S 0.0 0.0 0:01.34 ksoftirqd/4 37 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/4:+ 38 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/5 39 root rt 0 0 0 0 S 0.0 0.0 0:00.19 watchdog/5 40 root rt 0 0 0 0 S 0.0 0.0 0:00.07 migration/5 41 root 20 0 0 0 0 S 0.0 0.0 0:01.02 ksoftirqd/5 43 root 0 -20 0 0 0 I 0.0 0.0 0:00.00 kworker/5:+ 44 root 20 0 0 0 0 S 0.0 0.0 0:00.00 cpuhp/6 45 root rt 0 0 0 0 S 0.0 0.0 0:00.19 watchdog/6 46 root rt 0 0 0 0 S 0.0 0.0 0:00.08 migration/6 47 root 20 0 0 0 0 S 0.0 0.0 0:01.05 ksoftirqd/6
You can also use cpu_load.py to view your CPU load. Example run and output of cpu_load:
$ gs_cpu_load
Measuring CPU load for 2 seconds...
Overall: 15.21%
Individual CPUs: 13.60%  12.20%  15.20%  14.90%  14.60%  18.50%  15.80%  16.90%
See also my answer here: Stack Overflow: How to get overall CPU usage (e.g. 57%) on Linux and my Q&A here: Unix & Linux: How to get overall CPU usage (e.g. 57%) on Linux.
Gabriel Staples
  • 11,502
  • 14
  • 97
  • 142
