folks!
I want to check my CPU logs continuously. I used top and htop commands. But I just check them during simulations.
Now I want to run a real ROBOT for approx 2 hours (my laptop would be on ROBOT while moving).
So How can I save all the records in a log file so that I will access it later?
2ndly I also checked GPU (AMD graphics card) performance. But how can I make a log file?
First decide which CPU stats you want to log
You can choose different statistics to log:
  • CPU speed (frequency in Mhz or Ghz)
  • CPU utilization percentage
  • CPU temperature
  • CPU average load factor
  • Further these stats can be segmented for each CPU, ie #1 to #8 for quad-core hyper-threaded CPU.
For simplicity sake, I'll base this answer using average load factor similar to the answer in: How to log CPU load?
Create a loop for two hours logging every second
You'll need a bash script to loop 7,200 seconds (2 hours) which would look like this:
#!/bin/bash
for ((i=0; i<7200; i++))
do
    uptime >> /home/user/cpuload.log
    sleep 1
done
Parse the data in a spreadsheet
To look at your output use the command:
$ cat cpuload.log
 20:04:06 up 2 days, 14 min,  1 user,  load average: 1.39, 1.12, 0.95
The load average is reporting three variables--last minute, last five minutes and last fifteen minutes. For simplicity sake only consider the last minute load average which is reported every second in our loop.
You can import the file cpuload.log into a spreadsheet and graph the data points over the two hours or simply scroll over the data. I use Libre Office Calc but all modern spreadsheets can import the file.
Brief points about load average
In the example above the one minute load average is 1.39. This appears dangerously high because anything over .70 deserves investigation and 1.00 means there is a bottle-neck and processes aren't being served and have to wait.
However in your spreadsheet you'll have to divide the load average by the number of CPUs you have. To quickly find this out use the command:
$ cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_cur_freq
2074968
2133093
2094750
1863843
1728562
1855875
1849125
1778156
This shows there are 8 CPUs (it's a quad-core hyper-threaded Intel i-7 3630QM laptop CPU running 1200 Mhz to 3400 Mhz). In this snapshot CPU#1 (called CPU0 internally) is running at 2,0749.68 Mhz and CPU#8 is running at 1,7781.56 Mhz. But I digress, the important thing is to count how many CPUs there are which is 8.
So divide the load average 1.39 by 8 and the TRUE load average is 0.17 which is very respectable. Once again any value over 0.70 deserves investigation and when it hits 1.00 your system is stalling. You can read further here
Using top command to see top 10 processes
To use the top command to see the 10 most resource intensive processes use this command instead of the uptime command:
top -n 1 -b | head -n 17 | tail -n 10 >> /home/user/top10.log
The file /home/user/top10.log will look something like this (repeated every second for two hours):
$ top -n 1 -b | head -n 17 | tail -n 10
 6170 rick      20   0 1437432 537000 126060 S  62.5  6.7   8:50.24 chrome
 2466 rick      20   0 1210040 140568  61864 S   6.2  1.8  22:16.88 compiz
 4111 rick      20   0  742396 248724 185820 S   6.2  3.1  36:26.68 chrome
 6280 rick      20   0   41800   3668   3124 R   6.2  0.0   0:00.01 top
10096 root      20   0       0      0      0 S   6.2  0.0   0:00.47 kworker/0:2
    1 root      20   0  120064   6244   4000 S   0.0  0.1   0:02.23 systemd
    2 root      20   0       0      0      0 S   0.0  0.0   0:00.05 kthreadd
    3 root      20   0       0      0      0 S   0.0  0.0   0:01.31 ksoftirqd/0
    5 root       0 -20       0      0      0 S   0.0  0.0   0:00.00 kworker/0:+
    7 root      20   0       0      0      0 S   0.0  0.0   1:39.28 rcu_sched
NOTE: replace user with your actual user name.
Using top command to get us, sy, id and si CPU values
Similar to the first section, create a bash script to loop 7,200 seconds:
#!/bin/bash
# NAME: ~/bin/cpu-top-summary
# DATE: June 13, 2017
# DESC: Call `top` command every second to obtain CPU(s) stats for
#       us, sy, ni, id, wa, hi, si, and st. Log to /tmp/top-cpu-summary.log
#       with time stamp in hh:mm:ss 24 hour format.
# PARM: $1 number of seconds to run, ie 2 hours = 7200
now="$(date +'%d/%m/%Y')"
printf "top CPU(s) summary for %s\n" "$now" > /tmp/top-cpu-summary.log
for ((i=0; i<$1; i++))
do
    TimeStamp=`date +"%H:%M:%S"`
    printf "$TimeStamp - " >> /tmp/top-cpu-summary.log
    top -n 1 -b | head -n 3 | tail -n 1 >> /tmp/top-cpu-summary.log
    sleep 1
done
When you call the bash script using top-cpu-summary 10 you can see the output for 10 seconds using:
$ cat /tmp/top*
top CPU(s) summary for 13/06/2017
19:17:34 - %Cpu(s): 25.0 us,  9.2 sy,  0.0 ni, 65.4 id,  0.2 wa,  0.0 hi,  0.2 si,  0.0 st
19:17:35 - %Cpu(s): 25.0 us,  9.2 sy,  0.0 ni, 65.4 id,  0.2 wa,  0.0 hi,  0.2 si,  0.0 st
19:17:36 - %Cpu(s): 25.0 us,  9.2 sy,  0.0 ni, 65.4 id,  0.2 wa,  0.0 hi,  0.2 si,  0.0 st
19:17:37 - %Cpu(s): 25.0 us,  9.2 sy,  0.0 ni, 65.4 id,  0.2 wa,  0.0 hi,  0.2 si,  0.0 st
19:17:38 - %Cpu(s): 25.0 us,  9.2 sy,  0.0 ni, 65.4 id,  0.2 wa,  0.0 hi,  0.2 si,  0.0 st
19:17:39 - %Cpu(s): 25.0 us,  9.2 sy,  0.0 ni, 65.4 id,  0.2 wa,  0.0 hi,  0.2 si,  0.0 st
19:17:41 - %Cpu(s): 25.0 us,  9.2 sy,  0.0 ni, 65.4 id,  0.2 wa,  0.0 hi,  0.2 si,  0.0 st
19:17:42 - %Cpu(s): 24.9 us,  9.2 sy,  0.0 ni, 65.4 id,  0.2 wa,  0.0 hi,  0.2 si,  0.0 st
19:17:43 - %Cpu(s): 24.9 us,  9.2 sy,  0.0 ni, 65.4 id,  0.2 wa,  0.0 hi,  0.2 si,  0.0 st
19:17:44 - %Cpu(s): 24.9 us,  9.2 sy,  0.0 ni, 65.4 id,  0.2 wa,  0.0 hi,  0.2 si,  0.0 st
Rather than writing scripts yourself, you could use collectl and perhaps combine that with graphite and grafana to visualise the results.
From the collectl website:
There are a number of times in which you find yourself needing performance data. These can include benchmarking, monitoring a system's general heath or trying to determine what your system was doing at some time in the past. Depending on what you're doing, you often end up using different tools, each designed to for that specific situation.
Unlike most monitoring tools that either focus on a small set of statistics, format their output in only one way, run either interatively or as a daemon but not both, collectl tries to do it all. You can choose to monitor any of a broad set of subsystems which currently include buddyinfo, cpu, disk, inodes, infiniband, lustre, memory, network, nfs, processes, quadrics, slabs, sockets and tcp.
Collectl output can also be saved in a rolling set of logs for later playback or displayed interactively in a variety of formats. If all that isn't enough there are plugins that allow you to report data in alternate formats or even send them over a socket to remote tools such as ganglia or graphite. You can even create files in space-separated format for plotting with external packages like gnuplot.
nickcrabtree
  • 1,213
