27
I have a Windows server that runs postgresql 9.2. I want to hit it using pgAdmin III from my Ubuntu 12.10 workstation box.
I installed pgAdmin III from synaptic and also tried direct download from postgreSQL site using software installer. Regardless, I can get only get pgAdmin III for postgresql 9.1. When I run pgAdmin III and point to my server I get an error message telling me that the database is 9.2 and my pgAdmin III is for 9.1, isn't compatible with 9.2.
I can access the server itself fine OK from the Ubuntu box - I have Python programs that hit the database with no problems - but I need pgAdmin III for 9.2 running under Ubuntu 12.10.
Is it available? Where do I get it?
jokerdino
  • 41,732
Vector
  • 781
It is in the repositories.
sudo apt-get install pgadmin3
or search the software center.
software-center
If that is the wrong version, you could use the PPA:
If that does not work you can use the source and compile it yourself from source.
cprofitt
  • 6,605
15
As of 2014, this website describes the way to do it for Ubuntu and Debian: https://wiki.postgresql.org/wiki/Apt
Copy paste (2014-06-06) in case website goes offline, whatever happens:
PostgreSQL packages for Debian and Ubuntu
The PostgreSQL Global Development Group (PGDG) maintains an APT repository of PostgreSQL packages for Debian and Ubuntu located at http://apt.postgresql.org/pub/repos/apt/. We aim at building PostgreSQL server packages as well as extensions and modules packages on several Debian/Ubuntu releases for all PostgreSQL versions supported. Currently, we support Debian 6.0 (squeeze), 7.0 (wheezy), and unstable (sid) 64/32 bit (amd64/i386) Ubuntu 10.04 (lucid), 12.04 (precise), 13.10 (saucy), 14.04 (trusty) 64/32 bit (amd64/i386) PostgreSQL 8.4, 9.0, 9.1, 9.2, 9.3, 9.4 beta Server extensions such as Slony-I, various PL languages, and datatypes Applications like pgadmin3, pgbouncer, and pgpool-II Packages for older PostgreSQL versions and older Debian/Ubuntu distributions will continue to stay in the repository; updates for those will be provided on an ad-hoc basis.
Quickstart
Create /etc/apt/sources.list.d/pgdg.list. The distributions are called codename-pgdg. In the example, replace wheezy with the actual distribution you are using:
deb http://apt.postgresql.org/pub/repos/apt/ wheezy-pgdg main
(You may determine the codename of your distribution by running lsb_release -c.) Import the repository key from https://www.postgresql.org/media/keys/ACCC4CF8.asc, update the package lists, and start installing packages:
wget --quiet -O - https://www.postgresql.org/media/keys/ACCC4CF8.asc | sudo apt-key add -
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install postgresql-9.3 pgadmin3
Alternately, this shell script will do the above steps for you. 9.4 beta only: See FAQ on beta releases Have a look at the FAQ. Note: This repository provides "postgresql", "postgresql-contrib", and "postgresql-client" meta-packages that depend on the latest postgresql-x.y, ... packages, similar to the ones present in Debian and Ubuntu. Once a new PostgreSQL version is released, these meta-packages will be updated to depend on the new version. If you want to stay with a particular PostgreSQL version, you should install specific packages like "postgresql-9.3" instead of "postgresql".
domen
  • 261
Version 16 of pgadmin3 ( http://www.pgadmin.org/visualtour16.php ) is required for Postgres 9.2 and it is not in the repo or that PPA for Ubunutu 12.10.
It looks like you have to build it or upgrade.
I've built it for 12.10: https://copy.com/anB4E19CxdLW - perhaps that binary will work for you if you are on 12.10.
If not and you need to build it yourself, make sure you install
sudo apt-get install postgresql-server-dev-9.2
For pgAdmin 4, you can also refer to this wiki page: https://wiki.postgresql.org/wiki/Apt
I tried and installed pgAdmin 4 on Ubuntu 16.04:
sudo sh -c 'echo "deb http://apt.postgresql.org/pub/repos/apt/ $(lsb_release -cs)-pgdg main" > /etc/apt/sources.list.d/pgdg.list'
sudo apt-get install wget ca-certificates
sudo apt-get update
sudo apt-get install postgresql-10 pgadmin4
Yuci
  • 101
