I need to install pgadmin3 on Ubuntu, but it gives this message:
west@west-ThinkPad-T510:~$ sudo apt-get install pgadmin3
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
 pgadmin3 : Depends: libwxbase3.0-0 (>= 3.0.2) but 3.0.0-2 is to be installed
            Depends: libwxgtk3.0-0 (>= 3.0.2) but 3.0.0-2 is to be installed
            Recommends: pgagent but it is not going to be installed
I've googled it, but I didn't find a solution.
muru
  • 207,228
This is what I did to finally install pgadmin3:
First I checked the available version on the repository:
apt-cache policy pgadmin3
Then installed that version (may change in time, use the proper version shown by the previous command):
sudo apt-get install pgadmin3=1.22.2-1 pgadmin-data=1.22.2-1
As Elder Geek points out, you need to enable the universe repository
