110
I just wondered if somebody could tell me what this means:
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
reidsr@ubuntu:~$ sudo dpkg --configure -a
dpkg: error: dpkg status database is locked by another process
reidsr@ubuntu:~$
How do I run sudo dpkg --configure -a manually?
reidar
  • 1,251
10 Answers10
142
First run:
lsof /var/lib/dpkg/lock
Then make sure that process isn't running:
ps cax | grep PID
If it is running:
kill PID
#wait
kill -9 PID
Make sure process is done:
ps cax | grep PID
Then remove the lock file:
sudo rm /var/lib/dpkg/lock
Let dpkg fix itself:
You should be fine afterwards :)
helper
  • 1,429
32
In our case there was no running process (PID) so I hard-stopped and rebooted the VPS.
Next, there are several lock files that might need to be removed:
sudo rm /var/lib/dpkg/lock-frontend
sudo rm /var/cache/apt/archives/lock
Then you can fix dpkg as suggested:
sudo apt update
Jesse Nickles
  • 462
One could also try:
sudo apt-get install -f
To fix any broken packages:
Fix; attempt to correct a system with broken dependencies in place. This option, when used with install/remove, can omit any packages to permit APT to deduce a likely solution. If packages are specified, these have to completely correct the problem. The option is sometimes necessary when running APT for the first time; APT itself does not allow broken package dependencies to exist on a system. It is possible that a system's dependency structure can be so corrupt as to require manual intervention (which usually means using dselect(1) or dpkg --remove to eliminate some of the offending packages). Use of this option together with -m may produce an error in some situations. Configuration Item: APT::Get::Fix-Broken.
blade19899
  • 26,994
You can not run several packages applications/commands/tools at the same time. Sometimes, it means that synaptic, apt-get or the package update tool are running in the backgroung. Just close other package tools, or wait for them to be finished. And dpkg will run.
ttoine
  • 1,200
There are some good answers here, but just wanted to add a non-lsof method of finding the dpkg lock user
Step 1: Find out who is locking dpkg:
Option #1: Using lsof (not always installed on the machine)
Option #2: Using bash
for pid in $(ls /proc | egrep [0-9]+); do sudo ls -l /proc/$pid/fd 2>/dev/null | grep /var/lib/dpkg/lock && echo $pid; done
Step 2: Decide what you want to do with the current dpkg user
If there is no such process, there is nothing to decide, just skip to the next step.
Otherwise, you have to decide if you want to kill the process or let it finish gracefully. If you decide to kill it, just use kill <pid>. If the process still won't die, you can consider killing it using kill -9 <pid>, but it might create certain inconsistencies and I advise against it unless you know what you are doing.
Step 3: Remove the lock file
Step 4: Fix dpkg internal state
One approach is just to restart the PC. This worked for me.
Eliah Kagan
  • 119,640
Following should help:
No answer of this thread has solved it for me. I had removed the lock files, and there was no PID running, yet, whenever I executed sudo dpkg --configure -a, the shell was stuck at one of the previously locked "apt" tasks that I had force-closed by closing the terminal in the end. I also killed the apt processes using sudo killall apt apt-get. The stuck apt task in my case was "Setting up docker-ce (5:20.10.1~3-0~ubuntu-bionic)".
Solution in my case:
  • Boot in recovery mode.
  • In the recovery menu, choose "root" in order to "Drop to root shell prompt".
  • Press Enter.
  • Type 'sudo dpkg --configure -a'.
  • Go on with what you were about to do, it should work now, and / or just reboot.
Please see screenshots and detailed explanation (e.g. how to get the recovery mode at start) at the answer of docker ps stuck … docker install also just hangs.
One thing that's not mentioned - you could have unattended/automatic upgrades enabled. If so, unattended-upgr is likely holding the lock on dpkg. In that case, forcibly removing the lock file is NOT a good idea!
You can check if it's running using the following:
ps -A | grep unattended-upgr
You can also see if that's the process holding the lock using Step 1 of Daniel Trugman's answer. Option #2 (using bash) was the only one that showed me the PID that had the file locked, and pointed me to unattended-upgr.
AFAIK, your only two options are to patiently wait for the updates to finish, or temporarily disable unattended/automatic updates, install the needed package, and turn it back on.
This can happen if the upgrade process was interrupted (like you're connection was lost). You can try using screen as root (sudo su) to get back into the session.
screen -r
Xeoncross
  • 183
