16
i've just installed Ubuntu 12.04 on my new laptop ( with Win7 64bit pre installed ) in EFI mode and now i can't load Win7 anymore ( Ubuntu just loads fine from grub ). When i select the Windows 7 entry in the grub menu, i get this error:
Invalid EFI file path
The grub.cfg entry ( generated by boot-repair ) is:
menuentry "Windows 7 (loader) (on /dev/sda3)" --class windows --class os {
    insmod part_gpt
    insmod ntfs
    set root='(hd0,gpt3)'
    search --no-floppy --fs-uuid --set=root B8449665449625E2
    chainloader +1
This is the parted output :
GNU Parted 2.3
Viene usato /dev/sda
Benvenuti in GNU Parted. Digitare "help" per l'elenco dei comandi.
(parted) print list
Modello: ATA ST9500325AS (scsi)
Disco /dev/sda: 500GB
Dimensione del settore (logica/fisica): 512B/512B
Tabella delle partizioni: gpt
Numero Inizio Fine Dimensione File system Nome Flag 5 1049kB 106MB 105MB fat32 avvio 3 345MB 200GB 200GB ntfs Basic data partition 1 200GB 200GB 1049kB bios_grub 2 200GB 496GB 296GB ext4 4 496GB 500GB 4172MB
The boot EFI partition, mounted as
/dev/sda5 on /boot/efi type vfat (rw) )
has the following files ( excluding the grub folder and other files on the boot root ) :
./efi
./efi/efi
./efi/efi/boot
./efi/efi/boot/bootx64.efi
./efi/efi/ubuntu
./efi/efi/ubuntu/grubx64.efi
./efi/efi/Microsoft
./efi/efi/Microsoft/Boot
./efi/efi/Microsoft/Boot/bootmgfw.efi.grb
./efi/efi/Microsoft/Boot/bootx64.efi.grb
How can i fix this ?
Thanks
guiverc
  • 33,561
Your GRUB entry for Windows is appropriate for a BIOS-mode boot, but not for an EFI-mode boot. This is a GRUB bug. You can try replacing the entry with something like the following:
menuentry "Windows 7" {
    insmod part_gpt
    insmod chain
    set root='(hd0,gpt5)'
    chainloader /EFI/Microsoft/Boot/bootmgfw.efi
I make no guarantees that this will work, but it might. If it does, add that entry to /etc/grub.d/40_custom so that it will be created again whenever Ubuntu updates its GRUB configuration.
Another option is to use a different boot manager in addition to or instead of GRUB. rEFInd, for instance, will auto-detect both Windows and GRUB; and if you're using 3.3.0 or later kernels (as shipped with Ubuntu 12.10, but not with Ubuntu 12.04), you can boot Linux directly with rEFInd, bypassing GRUB entirely. gummiboot is another option with similar boot capabilities, but it requires more manual maintenance if you wanted to boot Linux directly with gummiboot.
Rod Smith
  • 45,120
  • 66
  • 108
Finally i've solved formatting and reinstalling everything from scratch ... basically ( don't know why ) grub had overwritten the windows 7 loader, that was the problem.
As of today, in Xubuntu 22.04, I have been using the information provided above for my laptop using UEFI. However now I have had to add the location of the ESP partition to the chainloader line.
This is what my working configuration looks like now:
menuentry "Windows 10" {
insmod part_gpt
insmod chain
set root='(hd0,gpt4)'
chainloader (hd0,gpt2)/EFI/Microsoft/Boot/bootmgfw.efi
Also, the file in which I have had to insert it in order for it to work, is the file " custom " located under /etc/grub.d/proxifiedScripts.
One more annoyance was occurring at the same time : several sets of entries had appeared in the Grub boot stanza for the same Xubuntu install (not several installs). I have used grub-customizer, installed from its PPA, to fix it.
It seemed to me that the different entries had been generated through several proxy files located under /etc/grub.d, probably 10_linux_proxy, 31_linux_proxy, and 41_linux_proxy.
I would not dare change the default settings manually, of course.
-1
This an Update to the Answer for this question -- Ubuntu 22.04 MATE either ignores or otherwise over wrote my Win 10 Pro boot ... a quick jump to Ventoy and loading the Win10 ISO installer and then select Repair Boot fixes the issue ... whether it comes back after a kernel update remains to be seen :P
Thx/Sx
guiverc
  • 33,561
Sn33x
