First, I installed Windows 8 in my desktop PC. (Not pre-installed... I did it by myself). Then I booted the Ubuntu dvd in UEFI mode (Did the same with Windows 8) and installed Ubuntu 12.10 64bit. Everything went perfectly. After rebooting, there's no grub! The system took me directly to Ubuntu! I can't log into Windows 8. Please help! Earlier, I used Boot Repair and it messd up with my Windows EFI files. So I was unable to boot Windows even after removing Ubuntu. I can't use boot repair. Now this is a new fresh install, Please tell me how to boot into both Windows 8 and Ubuntu!
Here is my /etc/defaults/grub :
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
#   info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=1024×768
#GRUB_GFXPAYLOAD_LINUX=1024×768
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
THpubs
  • 2,815
Run Boot-Repair --> Advanced Options --> tick Restore EFI backups --> Apply , and indicate the new URL that will appear. Reboot, you should get back access to Windows.
LovinBuntu
  • 3,785
I recently installed Windows 8 Pro to an extra hard drive on my PC. My system which runs Ubuntu primarily and boots up through GRUB couldn't seem to find the new OS after I installed it. So I searched and read all of these solutions involving manually re-configuring GRUB system files, uninstalling and re-installing Windows, etc. All of these are terrible solutions. The best solution is so, so easy. All you have to do is run this update command for GRUB from a terminal window within your Linux distro:
$ sudo update-grub
It searches your hard drives for new kernels and OSs. Problem Solved. Enjoy!
