I'm trying to setup a dual boot system with Windows Vista 64 (already installed) and Ubuntu 10.10. I added a new drive which is identical to the one Vista is installed on. When I boot into the LiveCD I can see and mount the second drive and edit it in Gparted. However, when I use the installer it will only bring up the drive that already has Vista installed.
I've tried everything I know. I'm not sure if its a BIOS setting or something else I've missed.
I've also tried both the desktop and alternate amd64 installs with the same result.
Braiam
  • 69,112
atodd
  • 163
6 Answers6
Try to boot a live session and start a terminal session (or to switch to the console with CTRL-ALT-F1) and issue:
sudo os-prober
You'll probably see a probing error which could be the reason why your drive is not taken in consideration. It's quite likely that your second drive has leftovers of a RAID configuration, in this case it's sufficient to do:
sudo dmraid -rE
(-r = raid, -E remove metadata) and confirm the operation. Start the installer and you should see it.
Jorge Castro
  • 73,717
oxullo
  • 156
sudo apt-get remove dmraid
This seems to have fixed the problem for me. At least now I'm not getting the empty drive box. It's asking me to choose from 3 options.
I had this issue when I had a partition type of GPD (had Windows 10 on the drive prior), to get around this I used fdisk to create a new 'dos' label.
In this day and age I'm amazed that the install doesn't account for this (and support GPD)
Hope this helps.
  • check with
    cat /proc/partitions
to see which partition is the new one (the size can give you a clue)
  • Create some dir to mount the disk
  • Add a line in /etc/fstab accordingly
Run
 sudo mount -a
jet
  • 7,452
Have you tried using the alternative installer iso? It is a hassle to use, but gives you much more control over the installation process.
This is just a hunch, I am not sure it will solve the problem. It requires an additional CD-sized download and about half an hour of answering prompts about things the graphical installer discovers automatically, so only try it if the easier methods have failed.
rumtscho
  • 1,051
I ran into a somewhat-similar installation issue when I was attempting to install Kubuntu 10.4 on a computer with Windows 7 installed. With the issue, I only had one hard drive, but it just wasn't showing in the partition list, even after I partitioned a good chunk off for the install.
The eventual solution revolved around the fact that the live cd had dmraid installed by default.
I live-booted into terminal, entered sudo apt-get remove dmraid and my issue was fixed. Hope it works for you as well.
