So my wifi works for a little bit (say 5-10 minutes) no issues. after that point, it stops.
Observations:
  1. When I click my wi-fi after it stops working I am still connected to the network(just not the internet)
  2. When I look at the list of networks around me, I can only see the one I am connected to.
  3. It started to happen around the time I upgraded to Bionic Beaver.
  4. If I turn the wifi on and off again it is completely unavailable (i.e the computer seems to think the wifi hardware does not exist)
lshw contents :
  8-bit
        description: Notebook
        product: Inspiron 5559 (06B2)
        vendor: Dell Inc.
        serial: 2YJXDC2
        width: 64 bits
        capabilities: smbios-2.8 dmi-2.8 smp vsyscall32
        configuration: boot=normal chassis=docking family=Inspiron sku=06B2 uuid=44454C4C-5900-104A-8058-B2C04F444332
      *-core
           description: Motherboard
           product: 052K07
           vendor: Dell Inc.
           physical id: 0
           version: A00
           serial: /2YJXDC2/CN1296365N0022/
         *-firmware
              description: BIOS
              vendor: Dell Inc.
              physical id: 0
              version: 1.2.8
              date: 02/08/2017
              capacity: 15MiB
              capabilities: pci pnp upgrade shadowing cdboot bootselect edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb smartbattery biosbootspecification netboot uefi
         *-cache:0
              description: L1 cache
              physical id: 41
              slot: L1 Cache
              capacity: 64KiB
              capabilities: synchronous internal write-back data
              configuration: level=1
         *-cache:1
              physical id: 42
              slot: L1 Cache
              capacity: 64KiB
              capabilities: synchronous internal write-back instruction
         *-cache:2
              description: L2 cache
              physical id: 43
              slot: L2 Cache
              capacity: 512KiB
              capabilities: synchronous internal write-back unified
              configuration: level=2
         *-cache:3
              description: L3 cache
              physical id: 44
              slot: L3 Cache
              capacity: 4MiB
              configuration: level=3
         *-cpu
              description: CPU
              product: Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz
              vendor: Intel Corp.
              physical id: 45
              bus info: cpu@0
              version: Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz
              serial: To Be Filled By O.E.M.
              slot: U3E1
              capacity: 3100MHz
              width: 64 bits
              clock: 100MHz
              capabilities: fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp x86-64 constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch cpuid_fault epb invpcid_single pti tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid mpx rdseed adx smap clflushopt intel_pt xsaveopt xsavec xgetbv1 xsaves ibpb ibrs stibp dtherm ida arat pln pts hwp hwp_notify hwp_act_window hwp_epp cpufreq
              configuration: cores=2 threads=4
         *-memory
              description: System Memory
              physical id: 46
              slot: System board or motherboard
            *-bank:0
                 description: SODIMM DDR3 Synchronous 1600 MHz (0.6 ns)
                 product: KHX1600C9S3L/8G
                 vendor: Kingston
                 physical id: 0
                 serial: 12151215
                 slot: DIMM A
                 width: 64 bits
                 clock: 1600MHz (0.6ns)
            *-bank:1
                 vendor: Kingston
                 physical id: 1
                 serial: 12121212
                 slot: DIMM B
                 width: 64 bits
         *-pci
              description: Host bridge
              product: Skylake Host Bridge/DRAM Registers
              vendor: Intel Corporation
              physical id: 100
              bus info: pci@0000:00:00.0
              version: 08
              width: 32 bits
              clock: 33MHz
              configuration: driver=skl_uncore
              resources: irq:0
            *-display
                 description: VGA compatible controller
                 product: HD Graphics 520
                 physical id: 2
                 bus info: pci@0000:00:02.0
                 version: 07
                 width: 64 bits
                 clock: 33MHz
                 capabilities: pciexpress msi pm vga_controller bus_master cap_list rom
                 configuration: driver=i915 latency=0
                 resources: irq:125 memory:d1000000-d1ffffff memory:b0000000-bfffffff ioport:f000(size=64) memory:c0000-dffff
            *-usb
                 description: USB controller
                 product: Sunrise Point-LP USB 3.0 xHCI Controller
                 physical id: 14
                 bus info: pci@0000:00:14.0
                 version: 21
                 width: 64 bits
                 clock: 33MHz
                 capabilities: pm msi xhci bus_master cap_list
                 configuration: driver=xhci_hcd latency=0
                 resources: irq:122 memory:d2210000-d221ffff
               *-usbhost:0
                    product: xHCI Host Controller
                    vendor: Linux 4.15.0-20-generic xhci-hcd
                    physical id: 0
                    bus info: usb@1
                    logical name: usb1
                    version: 4.15
                    capabilities: usb-2.00
                    configuration: driver=hub slots=12 speed=480Mbit/s
                  *-usb:0
                       description: Generic USB device
                       product: USB2.0-CRW
                       vendor: Generic
                       physical id: 6
                       bus info: usb@1:6
                       version: 39.60
                       serial: 20100201396000000
                       configuration: driver=rtsx_usb maxpower=500mA speed=480Mbit/s
                  *-usb:1 UNCLAIMED
                       description: Human interface device
                       product: LGD AIT Touch Controller
                       vendor: Melfas
                       physical id: 7
                       bus info: usb@1:7
                       version: 5.00
                       capabilities: usb-1.10
                       configuration: maxpower=100mA speed=12Mbit/s
                  *-usb:2
                       description: Bluetooth wireless interface
                       vendor: Intel Corp.
                       physical id: 8
                       bus info: usb@1:8
                       version: 0.01
                       capabilities: bluetooth usb-2.00
                       configuration: driver=btusb maxpower=100mA speed=12Mbit/s
               *-usbhost:1
                    physical id: 1
                    bus info: usb@2
                    logical name: usb2
                    version: 4.15
                    capabilities: usb-3.00
                    configuration: driver=hub slots=6 speed=5000Mbit/s
                  *-usb
                       description: Video
                       product: Intel(R) RealSense(TM) 3D Camera (Front F200)
                       vendor: Intel(R) RealSense(TM) 3D Camera (Front F200)
                       physical id: 3
                       bus info: usb@2:3
                       version: 27.80
                       serial: 032150074902
                       configuration: driver=uvcvideo maxpower=440mA speed=5000Mbit/s
            *-generic:0
                 description: Signal processing controller
                 product: Sunrise Point-LP Thermal subsystem
                 physical id: 14.2
                 bus info: pci@0000:00:14.2
                 version: 21
                 width: 64 bits
                 clock: 33MHz
                 capabilities: pm msi cap_list
                 configuration: driver=intel_pch_thermal latency=0
                 resources: irq:18 memory:d2230000-d2230fff
            *-generic:1
                 product: Sunrise Point-LP Serial IO I2C Controller #0
                 physical id: 15
                 bus info: pci@0000:00:15.0
                 version: 21
                 width: 64 bits
                 clock: 33MHz
                 capabilities: pm bus_master cap_list
                 configuration: driver=intel-lpss latency=0
                 resources: irq:16 memory:d222f000-d222ffff
            *-generic:2
                 product: Sunrise Point-LP Serial IO I2C Controller #1
                 physical id: 15.1
                 bus info: pci@0000:00:15.1
                 version: 21
                 width: 64 bits
                 clock: 33MHz
                 resources: irq:17 memory:d222e000-d222efff
            *-communication
                 description: Communication controller
                 product: Sunrise Point-LP CSME HECI #1
                 physical id: 16
                 bus info: pci@0000:00:16.0
                 version: 21
                 width: 64 bits
                 clock: 33MHz
                 capabilities: pm msi bus_master cap_list
                 configuration: driver=mei_me latency=0
                 resources: irq:127 memory:d222d000-d222dfff
            *-storage
                 description: SATA controller
                 product: Sunrise Point-LP SATA Controller [AHCI mode]
                 physical id: 17
                 bus info: pci@0000:00:17.0
                 version: 21
                 width: 32 bits
                 clock: 66MHz
                 capabilities: storage msi pm ahci_1.0 bus_master cap_list
                 configuration: driver=ahci latency=0
                 resources: irq:123 memory:d2228000-d2229fff memory:d222c000-d222c0ff ioport:f090(size=8) ioport:f080(size=4) ioport:f060(size=32) memory:d222b000-d222b7ff
            *-pci:0
                 description: PCI bridge
                 product: Intel Corporation
                 physical id: 1c
                 bus info: pci@0000:00:1c.0
                 version: f1
                 width: 32 bits
                 clock: 33MHz
                 capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
                 configuration: driver=pcieport
                 resources: irq:16 ioport:e000(size=4096) memory:c0000000-d00fffff
               *-display
                    description: Display controller
                    product: Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430]
                    vendor: Advanced Micro Devices, Inc. [AMD/ATI]
                    physical id: 0
                    bus info: pci@0000:01:00.0
                    version: 81
                    width: 64 bits
                    clock: 33MHz
                    capabilities: pm pciexpress msi bus_master cap_list rom
                    configuration: driver=radeon latency=0
                    resources: irq:126 memory:c0000000-cfffffff memory:d0000000-d003ffff ioport:e000(size=256) memory:d0040000-d005ffff
            *-pci:1
                 product: Sunrise Point-LP PCI Express Root Port #5
                 physical id: 1c.4
                 bus info: pci@0000:00:1c.4
                 version: f1
                 width: 32 bits
                 clock: 33MHz
                 resources: irq:16 memory:d2100000-d21fffff
               *-network
                    description: Wireless interface
                    product: Wireless 3160
                    physical id: 0
                    bus info: pci@0000:02:00.0
                    logical name: wlp2s0
                    version: 83
                    serial: 2c:6e:85:ef:ff:97
                    width: 64 bits
                    clock: 33MHz
                    capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
                    configuration: broadcast=yes driver=iwlwifi driverversion=4.15.0-20-generic firmware=17.608620.0 ip=192.168.0.21 latency=0 link=yes multicast=yes wireless=IEEE 802.11
                    resources: irq:128 memory:d2100000-d2101fff
            *-pci:2
                 product: Sunrise Point-LP PCI Express Root Port #6
                 physical id: 1c.5
                 bus info: pci@0000:00:1c.5
                 version: f1
                 width: 32 bits
                 clock: 33MHz
                 resources: irq:17 ioport:d000(size=4096) memory:d2000000-d20fffff
               *-network
                    description: Ethernet interface
                    product: RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
                    vendor: Realtek Semiconductor Co., Ltd.
                    physical id: 0
                    bus info: pci@0000:03:00.0
                    logical name: enp3s0
                    version: 07
                    serial: 84:7b:eb:45:9f:1d
                    capacity: 100Mbit/s
                    width: 64 bits
                    clock: 33MHz
                    capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
                    configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8106e-1_0.0.1 06/29/12 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
                    resources: irq:124 ioport:d000(size=256) memory:d2004000-d2004fff memory:d2000000-d2003fff
            *-isa
                 description: ISA bridge
                 product: Sunrise Point-LP LPC Controller
                 physical id: 1f
                 bus info: pci@0000:00:1f.0
                 version: 21
                 width: 32 bits
                 clock: 33MHz
                 capabilities: isa bus_master
                 configuration: latency=0
            *-memory UNCLAIMED
                 description: Memory controller
                 product: Sunrise Point-LP PMC
                 physical id: 1f.2
                 bus info: pci@0000:00:1f.2
                 version: 21
                 width: 32 bits
                 clock: 33MHz (30.3ns)
                 resources: memory:d2224000-d2227fff
            *-multimedia
                 description: Audio device
                 product: Sunrise Point-LP HD Audio
                 physical id: 1f.3
                 bus info: pci@0000:00:1f.3
                 version: 21
                 width: 64 bits
                 clock: 33MHz
                 configuration: driver=snd_hda_intel latency=32
                 resources: irq:129 memory:d2220000-d2223fff memory:d2200000-d220ffff
            *-serial UNCLAIMED
                 description: SMBus
                 product: Sunrise Point-LP SMBus
                 physical id: 1f.4
                 bus info: pci@0000:00:1f.4
                 version: 21
                 width: 64 bits
                 clock: 33MHz
                 resources: memory:d222a000-d222a0ff ioport:f040(size=32)
         *-scsi:0
              physical id: 1
              logical name: scsi0
              capabilities: emulated
            *-disk
                 description: ATA Disk
                 product: Samsung SSD 850
                 physical id: 0.0.0
                 bus info: scsi@0:0.0.0
                 logical name: /dev/sda
                 version: 3B6Q
                 serial: S3PTNF0JC24293F
                 capabilities: gpt-1.00 partitioned partitioned:gpt
                 configuration: ansiversion=5 guid=d945d3a7-3e90-4378-a83c-7b21f7aee6c2 logicalsectorsize=512 sectorsize=512
               *-volume:0 UNCLAIMED
                    description: Windows FAT volume
                    vendor: mkfs.fat
                    physical id: 1
                    bus info: scsi@0:0.0.0,1
                    version: FAT32
                    serial: 673e-facf
                    capacity: 511MiB
                    capabilities: boot fat initialized
                    configuration: FATs=2 filesystem=fat name=EFI System Partition
               *-volume:1
                    description: EXT4 volume
                    vendor: Linux
                    physical id: 2
                    bus info: scsi@0:0.0.0,2
                    logical name: /dev/sda2
                    logical name: /
                    version: 1.0
                    serial: 1ea817d6-3df0-4153-b7ea-5ef27eee2d15
                    capabilities: journaled extended_attributes large_files huge_files dir_nlink recover 64bit extents ext4 ext2 initialized
                    configuration: created=2018-02-24 18:34:12 filesystem=ext4 lastmountpoint=/ modified=2018-05-12 12:45:14 mount.fstype=ext4 mount.options=rw,relatime,errors=remount-ro,data=ordered mounted=2018-05-12 12:45:15 state=mounted
         *-scsi:1
              physical id: 2
              logical name: scsi1
            *-cdrom
                 description: DVD-RAM writer
                 product: DVD+-RW SU-208GB
                 vendor: TSSTcorp
                 physical id: 0.0.0
                 bus info: scsi@1:0.0.0
                 logical name: /dev/cdrom
                 logical name: /dev/cdrw
                 logical name: /dev/dvd
                 logical name: /dev/dvdrw
                 logical name: /dev/sr0
                 version: H100
                 capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
                 configuration: ansiversion=5 status=nodisc
      *-battery
           product: DELL 991XP65
           vendor: LG
           physical id: 1
           version: 04/28/2016
           serial: 93C6
           slot: Sys. Battery Bay
           capacity: 41440mWh
           configuration: voltage=14.8V
Here is the output of lspci command (while the internet works - when it happens again ill run it the 2nd time)
$ lspci -knn | grep Net -A3
02:00.0 Network controller [0280]: Intel Corporation Wireless 3160 [8086:08b3] (rev 83)
        Subsystem: Intel Corporation Dual Band Wireless AC 3160 [8086:8470]
        Kernel driver in use: iwlwifi
        Kernel modules: iwlwifi
^^ This is while it is working.
These are the exact logs i get now (reinstalled ubuntu)
May 17 17:59:13 8-bits kernel: [  359.017391] iwlwifi 0000:02:00.0: Failed to wake NIC for hcmdsystem
May 17 17:59:13 8-bits kernel: [  359.017478] iwlwifi 0000:02:00.0: Error sending SCAN_OFFLOAD_REQUEST_CMD: enqueue_hcmd failed: -5
May 17 17:59:13 8-bits kernel: [  359.017490] iwlwifi 0000:02:00.0: Scan failed! ret -5
May 17 17:59:14 8-bits kernel: [  360.037034] iwlwifi 0000:02:00.0: Failed to wake NIC for hcmd
May 17 17:59:14 8-bits kernel: [  360.037063] iwlwifi 0000:02:00.0: Error sending SCAN_OFFLOAD_REQUEST_CMD: enqueue_hcmd failed: -5
May 17 17:59:14 8-bits kernel: [  360.037066] iwlwifi 0000:02:00.0: Scan failed! ret -5
May 17 17:59:14 8-bits kernel: [  360.660055] usb usb1-port7: Cannot enable. Maybe the USB cable is bad?
Turn off or enable power savings as illustrated below:
$ cat /etc/NetworkManager/conf.d/default-wifi-powersave-on.conf
[connection]
wifi.powersave = 3
# Slow sleep fix: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1670041
#wifi.powersave = 2
  • Edit the Network Manager file shown above.
  • Change WiFi.powersave from 2 to 3.
  • If it's already set to 3 try setting it to 2.
  • After saving the file run sudo systemctl restart NetworkManager
What the values represent?
  • NM_SETTING_WIRELESS_POWERSAVE_DISABLE (2): disable powersave
  • NM_SETTING_WIRELESS_POWERSAVE_ENABLE (3): enable powersave
Source
Intel specific answer
From this answer you can try:
You can fix it by running in terminal
sudo tee /etc/modprobe.d/iwlwifi-opt.conf <<< "options iwlwifi 11n_disable=1"
then reboot.
You can revert it by sudo rm /etc/modprobe.d/iwlwifi-opt.conf.
To keep the 802.11n, you can try the 11n_disable=8 option.
From this Q&A you can try:
sudo modprobe -r iwlwifi
sudo modprobe iwlwifi
If this works for the current session, it can be setup to run automatically on startup.
