Following this question I exported various SVGs to PNGs, but there is a little problem, all files include in their name the extensions .svg and .png as in file.svg.png.
Now what I'd like to know is how can I remove the .svg string from the name of the file without going trough each file and do right-click>rename?.
Uri Herrera
  • 15,318
I guess this answer to another question could help :)
Specific to the question:
rename s/".svg"/""/g *
General:
rename s/"**TO-BE-REPLACED**"/"**REPLACEMENT**"/g *
pyrenamer is a pretty handy tool for batch renaming files. Otherwise, you could always fire up the terminal.
for file in *; do mv "${file}" "${file//\.svg/}"; done
That should do the trick if you're in the same directory as the pictures. Use at own risk.
carestad
  • 992
