I have Windows 7 as my Host OS which has wired Ethernet working. My guest OS on VirtualBox is Ubuntu 12.04. The problem is that I cannot browse.
I have:
  1. Enabled sharing on Windows;
  2. Have used NAT, Bridged Adapter etc ( all possible combinations);
  3. With NAT, used PCnet-FAST II (Am79c973) combination.
Ubuntu says "connected to wired ethernet1" but I cannot access websites.
VirtualBox Host-Only Network in the Network and Sharing center shows that I don't have IPV4 and IPV6 connectivity.
Meaning I don't have DHCP configured. Strangely I have DNS address correct in the Ubuntu properties.
Peachy
  • 7,235
  • 40
  • 47
Muzab
  • 39
For Internet access you can change network option to this :
I had this problem and solve with this option.
A1Gard
  • 260
If you still have this issue of networking, try this.
Choose Bridged Adapter as said before boot your guest os (i.e ubuntu).
Try to ping any website from terminal. If you get 'unknown host' as the reply, the issue probably lies at DNS level.
To fix it, go and check if '/etc/resolv.conf' file exits and its contents. You should have atleast one name server entered by Network manager inside the file.
Note: There is also a directory called /etc/resolvconf. we are not concerned about it.
If the above file does not exist, do create one.
$sudo vim /etc/resolv.conf
and then enter this
nameserver <YOUR_DNS_IP_ADDRESS>
Save the file (press escape followed by : followed by wqa)
Hope internet works now.
Prashere
  • 317
