14
I use Ctrl-P very frequently to scroll backward in the command history, but I often mistype it as Mod4-P, which is bound to the switch display function.
I've searched around Keyboard shortcuts and CompizConfig, etc., but I couldn't find where Mod4-P is bound. What controls that?
Marco Ceppi
  • 48,827
Lenik
  • 10,608
5 Answers5
Disregard my other answer, it's incorrect.
There are laptops out there that have a physical button for video output switching hardcoded to send Win+p. This is why Ubuntu now interpets Win+p as a video output switching key.
This is hardcoded in gnome-settings-daemon and can be disabled in gconf by setting
/apps/gnome_settings_daemon/plugins/xrandr/active
to false. This workaround probably has a nasty side effect of breaking your real video switch key, if you have one.
P.S. This feature is added via an Ubuntu-specific debian/45_support_new_video_key.patch, but upstream gnome-settings daemon will do the same thing in a different gnome-settings-daemon plugin (media-keys). It is therefore likely that this gconf workaround will stop working in Natty.
P.P.S. There's an open bug claiming that stealing Win+p this way is not nice for people who have sane hardware and want to use it for something else.
Ubuntu 14.04 simply:
dconf write /org/gnome/settings-daemon/plugins/media-keys/active false
At the command line :)
Leo Gallucci
  • 336
  • 14
Install compizconfig-settings-manager, run it, press Advanced Search >, enable the checkbox for searching in setting values, and do a search for <Super>p (and <Mod4>p, just in case -- both spellings appear to work).
On my machine I find that <Super>p is bound by two disabled plugins: ADD Helper and Shelf.
For newer versions of Ubuntu, dconf is used (instead of gconf) for changing the gnome-settings-daemon setting: see this question.
Mark
  • 1,479
On Ubuntu Quantal
Find all bindings to Super-p
gconftool-2 -R /apps | grep "<Super>p"
gconftool-2 -R /system | grep "<Super>p"
Unbind them
gconftool-2 -s /apps/compiz-1/plugins/shelf/screen0/options/triggerscreen_key "" --type String
gconftool-2 -s /apps/compiz-1/plugins/addhelper/screen0/options/toggle_key "" --type String
