18
Possible Duplicate:
How do I resolve unmet dependencies?
TL;DR: sudo apt-get install ... saying "Unable to correct problems, you have held broken packages."
The problem
I was trying to get the WebApps feature for PP and QQ following this blog post.
I ran the sudo add-apt-repository ppa:webapps/preview command to add the repository, but i got a connection error. Since I know my current ISP gives a shaky connection, I tried again and sure enough, it worked.
Then I ran sudo apt-get install unity-webapps-preview, but I realized we had to update apt-get first, so I hit Ctrl + C to stop it. Then I ran sudo apt-get update which worked w/o a fuss, but when I ran sudo apt-get install unity-webapps-preview again later, it showed an error message. Here's the dump:
Reading package lists... Done
Building dependency tree
 unity-webapps-preview : Depends: xul-ext-unity but it is not going to be installed
                         Depends: xul-ext-websites-integration but it is not going to be installed
                         Depends: xul-ext-webaccounts but it is not going to be installed
I think this might be because of me interrupting the earlier command. It hadn't got a chance to output anything, though — I stopped it pretty fast.
What I tried
Commands
I tried these:-
  • sudo apt-get install --fix-broken
  • sudo apt-get autoclean
  • sudo apt-get autoremove
  • sudo apt-get -f install
But even after running sudo apt-get upgrade after every try, none of them worked.
Purging
I tried purging the repository, but that didn't work either. First, I got the package using sudoapt-get install ppa-purgeand then tried to purge the WebApps repo usingsudo ppa-purge ppa:webapps/preview`.
Manually installing dependencies
If you look at the error dump carefully, it says:
Depends: xul-ext-unity but it is not going to be installed Depends: xul-ext-websites-integration but it is not going to be installed Depends: xul-ext-webaccounts but it is not going to be installed
So I tried installing them manually. I ran sudo apt-get install xul-ext-unity, but got this:
Depends: xul-ext-websites-integration but it is not going to be installed Breaks: firefox (>= 15.+) but 16.0~b6+build1-0ubuntu0.12.04.1~mfn4 is to be installed
I have no idea what the second part means, but I tried resolving the first. Running sudo apt-get install xul-ext-websites-integration gave:
xul-ext-websites-integration : Breaks: firefox (>= 15.+) but 16.0~b6+build1-0ubuntu0.12.04.1~mfn4 is to be installed
As a last resort, I tried sudo apt-get install xul-ext-webaccounts, but that gave the sane message too:
Breaks: firefox (>= 14.+) but 16.0~b6+build1-0ubuntu0.12.04.1~mfn4 is to be installed
What does Breaks: firefox (>= 14.+) but 16.0~b6+build1-0ubuntu0.12.04.1~mfn4 is to be installed mean?
Research
I tried searching Google, looking at a couple of forums, looking at this question and searching on AU, but to no avail. Help would be appreciated.
Yatharth Agarwal
  • 839
  • 23
try sudo apt-get -f install command
Vikramjeet
  • 5,936
  • 37
  • 43
