I'm trying to install VLC on Ubuntu by using the following commands:
sudo apt-get update && sudo apt-get upgrade
sudo apt-get install vlc
After trying to run the first command, an error is thrown:
E: Some index files failed to download. They have been ignored, or old ones used instead.
After running the second second command it gives another error:
What to do?
aastefanov
  • 1,399
Thanks everyone for helping.My problem is solved.In /etc/apt/sources.list i double click the sources.list file and change the server location to main server.Thats it.Now every command is running like Sudo apt-get update sudo apt-get upgrade sudo apt-get install vlc.Thanks everyone once again.
