22
Ubuntu 12.04 64bit refuses to hibernate when battery is critically low. Instead it does a complete shutdown which is unnecessary and can cause loss of data.
I have enabled Hibernate (pm-hibernate) on following the common instructions I tested pm-hibernate it is works fine when run manually.
I have set my power options to hibernate "When Power is Critically Low". This has also been verified by using dconf Editor. Under org > gnome > settings-daemon > plugins > power > critical-battery-action it is set to "hibernate". Under the same schema, time-action is set to "120".
I would like to see what is happening just prior to this shutdown. I would like to know what logs to search to see if pm-hibernate is actually failing, or if it is being ignored entirely.
Barring figuring this out on my own, is there a suggested work around?
swysocki
  • 341
I found another solution for my Ubuntu 14.04 system. Maybe it works for you.
First, install laptop-mode-tools
sudo apt-get install laptop-mode-tools
Then, you must enable the auto-hibernate function. You must edit a text file:
sudo gedit /etc/laptop-mode/conf.d/auto-hibernate.conf
There, look for ENABLE_AUTO_HIBERNATION parameter and replace the 0 with a 1:
ENABLE_AUTO_HIBERNATION=1
In the same file, you also want to adjust the battery charge percentage when the computer hibernates. For example:
AUTO_HIBERNATION_BATTERY_CHARGE_PERCENT=3
Save the file and test the configuration letting your battery discharge. If it works, you must set laptop-mode-tools as default, by creating a script:
sudo touch /etc/pm/sleep.d/10-laptop-mode-tools
sudo chmod a+x /etc/pm/sleep.d/10-laptop-mode-tools
sudo gedit /etc/pm/sleep.d/10-laptop-mode-tools
Then, in gedit, copy and paste this:
case $1 in
    hibernate)
        /etc/init.d/laptop-mode stop
    suspend)
    thaw)
        /etc/init.d/laptop-mode start
    resume)
        echo Something is not right.
esac
Save the file, then restart the system and test again. I hope that it works for you.
In my opinion, it looks like something is interfering with the the gnome-power-manager. If someone else reproduces the problem, then we can report a bug.
References:
Tips for save power by Penalvch https://help.ubuntu.com/community/PowerManagement/ReducedPower#Using_less_power_with_laptop-mode-tools
Re: Getting Ubuntu to automatically suspend on battery low (command-line) by Isamu715 http://ubuntuforums.org/showthread.php?t=2092327&p=12394451#post12394451
Goghard
  • 511
I have/had the same problem with 12.04 non-precise power monitoring, some possibilities:
(to cut to the chase and avoid the rhetoric read the final point - it is irritating that a "fix" is needed to restore such mundane and ordinary functionality)
  1. Unity and 12.04 do not provide the functionality of 10.04 that has more robust reliability, especially power management, so regression is the option I use. The sophisticated maturation of a computing system environment (Debian, GNU, Linux, ...) requires a high degree of comparable rigorous discipline to retain and modify functionality consistently. Consequently, several well established software paradigms have degraded and been compromised including power management.
  2. reference:
    Bug #993440 “No suspend option for critical battery state in pow...” : Bugs : “gnome-control-center” package : Ubuntu:
    solution: (manually labour intensive)
    lp:~jlangvand/ubuntu/quantal/gnome-control-center/fix-for-993440
  3. Write a script (more manually labour intensive) using pm-hibernate (pm-suspend), watch, upower, grep etc. to monitor the battery state and take action when required.
    pseudo code outline:
    Use watch, every few minutes, to periodically compare grep upower -d battery stats to gsettings get org.gnome.settings-daemon.plugins.power percentage-critical, and when threshold is exceeded sudo pm-hibernate
    crude (as in prototyping only, non-executable) draft: (suspend for any battery % < 10%)
    upower --monitor-detail | grep "percentage[^\d]+\d\.\d*\%" | bash pm-suspend
    an elegant solution
    • aborts further watching on suspend
    • checks all transient power supplies: UPS's, tertiary batteries, solar panels (power diminishes at dusk and by clouds), etc.
    • allows for non-privileged suspension (/ hibernation) for restricted users
refs:
Battery performance can be examined with:
  • upower
    • watch -d upower -i /org/freedesktop/UPower/devices/battery_BAT0
    • upower --monitor-detail | grep percentage
  • gnome-power-statistics
How to check battery status using terminal?
How can I find the discharge rate of the battery?
guest
  • 41
