57
Going to install Ubuntu 10.10 on new intel x25M 80GB SSD. It will be fresh install. I have been googling for past few days and getting overwhelming articles/blogs/Q&As. One particularly very useful being:
How do I optimize the OS for SSDs?
But with so many suggestions and differences of opinions (on different links) this simple OS install process seems to be daunting task to me and I really want to stick with Ubuntu (although have used for very short period of time).
Can someone help me by answering few questions (yes, they are repeated because I couldn't comprehend the answers elsewhere)
  1. Which file system (ext2/3/4 or something else)? (consider SSD life)
  2. Can it be changed after installation?
  3. Should I partition the disk? (as we do in traditional HDD) for now, no plan of dual booting. Only Ubuntu will live on scarce space of 80GB SSD.
  4. I have 2 GB RAM, should i still allocate swap space (if I don't allocate swap space, can I still hibernate the machine)? will swap space impact SSD life?
  5. Should I consider putting additional 1GB RAM to avoid swap space?
  6. What is partition aligning? Is it needed to be done before installing the Ubuntu OS or can be done later?
Intended usage - heavy browsing, programming, regular video/music and some other non-CPU/RAM-intensive programs. Will keep big files in an external hard drive.
laptop config - 3yr old Vaio, Core2 Duo, 2GB RAM
More references:
kunal
  • 767
5 Answers5
58
I'll start by saying that the answer you linked already summarizes all the optimizations you may need.
Next, to answer your questions:
ext4 is a good filesystem even for SSD, so that would be my suggestion. (If you want performance so bad you should try XFS )
Yes, but it is not trivial, so choose well from the start :)
This is really not a matter of SSD, but your personal choice. If you were to ask me I'll say no; don't partition the disk you will end in loosing useful space. (If you end with a partition with 2GB free and another with 1GB free, you theoretically have 3Gb free but cannot copy a 3GB file... that space is wasted )
4. I have 2 GB RAM, should I still allocate swap space (if I dont allocate swap space, can i still hibernate the machine)? will swap space impact SSD life? I wouldn't worry so much about the SSD life ( modern one can run for decades ), however 2GB of RAM are enough not to need the swap partition. Finally the swap partition is needed in order to hibernation, so if you want to hibernate the machine then you need the swap partition.
5. Should I consider putting additional 1GB RAM to avoid swap space? 1GB more or ram is always useful :) do it if you can.
6. What is partition aligning? is it needed to be done before installing the Ubuntu OS or can be done later?
That is the procedure where you align clusters, blocks and chunks. IMHO it is only needed on servers with a lot of data throughput. A good tool to do partition alignment is GParted. Of course this should be done before installing Ubuntu.
Hope this helps :)
Luis Alvarado
  • 216,643
OpenNingia
  • 3,323
I will try to answer the questions that I can:
  1. EXT4 Is one of the best filesystems currently available, so I'd suggest going with this.
  2. You can change some linux file systems after installation (ext3->ext4, ext4->btrfs, for example). Here is a link that explains changing ext3 to ext4.
  3. Not the clearest of questions, but Ubuntu will automatically create partitions.
  4. and 5.You will need swap space of equal or greater size (in relation to your RAM), in order to hibernate. So long as you are not doing anything intensive, your system will mostly avoid using swap so long as there is sufficient RAM. Maybe a good consideration would be to add more RAM if possible - give it about 4GB. If you don't allocate swap space, there is another option (not recommended) - hibernating to a file (I will add the links to my answer later).
Best wishes! I will update my answer with relevant links, as well as possibly resources for learning Ubuntu/Linux :).
RolandiXor
  • 51,797
Concerning Swap on SSDs:
I wouldn't care too much about putting a swap-partition on a SSD. The swap is, like said before, only used if there's no RAM left. But then there are "few" sequential writes and "many" random reads. That's exactly a form of usage SSDs excel in. - The same principle is used by microsofts "readyboost" technologie, only with USB-Flashdrives.
Not to throw a monkey wrench in, but checking what the manufacturer of the SSD says about the need for those techniques might pay off.
The folks who made my SDD assert that I don't need to worry about TRIM and optimizations, etc. They claim their firmware makes all of that unnecessary, that the SSD should be used like any other drive. I took them at their word and so far so good.
jonc
  • 259
I would recommend against having any swap space on your 80G SSD card. The swap space, as it names implies, is a location where the files are read/written all the time, when your computer is heavily loaded. The SSD-based disks should not be read/written all the time, as each "cell" or allocation unit is meant to be read/written so many times, after which they are no more reliable. You should invest in more RAM, even if it is overkill. Then, monitor your RAM usage over a heavily loaded session (lots of browser, videos, compiler, etc). For the file system, I would stick with what Ubuntu offers. You can: - manually partition your disk, allocating all the remaining space to one or more ext3 partition(s).That would be the recommended one, as you don't waste space. - go with the default partition setup, then delete the swap partition
jfmessier
  • 6,366
