21
I have an SSD with 64 GB and a 6 GB/s 1 Terabyte hard drive. I want to use the SSD only as a boot device and maybe for swap storage. On the 1 Terabyte hard drive, I want to have the main file system. As in Windows, I liked to have at least 2-3 Partitions example for music games programs and so on.
Which partition layout do you recommend to me?
64GB is more than enough for a root filesystem, a default installation will probably occupy about 3GB. When installing Ubuntu, choose for a custom partitioning scheme:
  • Put a partition on your SSD with mount point /
  • On your 1 TB data disk, create a partition with /home
Variations are possible. You can store all your settings and documents on the SSD and store large files like music and video on the 1TB disk:
  • Install Ubuntu to /
  • Create some partitions on your 1 TB disk, and mount those on /media/DESIRED-PARTITION-NAME.
Some folders in your home folder may become too large for the SSD, like ~/.wine. In that case, create a partition (or folder) on your 1 TB disk named "DATA" (with /media/DATA as mount point). Then, move the ~/.wine folder to the data partition:
mv ~/.wine /media/DATA/wine
If you've just installed the system and the folder did not exist yet, just create the empty folder:
mkdir /media/DATA/wine
Next, create a symbolic link from your home directory to the wine folder on the big disk:
ln -s /media/DATA/wine ~/.wine
The latter can also be performed after installation of Ubuntu to the SSD. Use GParted to create partitions on the 1 TB disk.
Related SSD questions:
Lekensteyn
  • 178,446
12
Do not put swap on the ssd. Put it on the hdd. Some pointers about swap and ssd: Installing Ubuntu on a SSD
Do make sure you enable trim on the SSD: How to enable TRIM?
My personal layout that works best for me:
  • / 20 Gb (sda1) (is on a 120 Gb ssd); gets formatted every time I re-install.
  • swap 4 Gb (sdb1).
  • /home 15 Gb. (sdb2) Holds only settings, no userfiles. I remove all directories after install and symlink them to /discword/; gets formatted every time I re-install. After format I recreate the symlinks and press F5 on my desktop to get all my video files back I had on my desktop.
  • /discworld (sdb3) is my data partition. Has a /discword/Downloads/ and /discworld/Desktop/ etc. Never gets formatted.
  • /disworld2/ (sda2) is the 100 Gb remainder of my SSD. Unused; never gets formatted.
You can set this up during installation with the something else option (i.e. manual partitioning).
Rinzwind
  • 309,379
