Possible Duplicate:
How to list all installed packages?
How do I list installed software with the installed size?
is there a way to know what are the packages installed on my machine, detailed information, like each software and its version? Like to know if I have qt installed and what version, or gcc and what version. Thanks
In a terminal, you can do a
dpkg --list
to get an overview of all installed packages including their version numbers. Since this generates usually a long output, you might consider to do
dpkg --list | less
or
dpkg --list | grep qt
To List all packages installed
dpkg --get-selections
To get details about particular package version use
  • dpkg -l <package_name>
    or
  • apt-cache policy <package_name>
Example:
$ dpkg -l perl
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name           Version      Architecture Description
ii  perl           5.14.2-13    i386         Larry Wall's Practical Extraction
$ apt-cache policy perl
perl:
  Installed: 5.14.2-13
  Candidate: 5.14.2-13
  Version table:
 *** 5.14.2-13 0
        500 http://in.archive.ubuntu.com/ubuntu/ quantal/main i386 Packages
        100 /var/lib/dpkg/status
To show the version along with the installed package. use
apt-show-versions
If apt-show-versions is not installed use sudo apt-get install apt-show-versions
devav2
  • 37,290
