I am having trouble upgrading the packages in my Ubuntu system. I followed the solution in the question here by using it I was able to troubleshoot the error I was encountering while doing dpkg --configure -a by removing the broken packages from the file in /var/lib/dpkg/status but now after doing apt-get install -f I get the following error. Please Help.
I dont know because will removing the below packages from the file will cause any problem in my system.
apt-get install -f
Reading package lists... Done
Building dependency tree
Correcting dependencies... failed.
  apparmor: Depends: initramfs-tools but it is not installed
  brltty: Depends: initramfs-tools (>= 0.40ubuntu30) but it is not installed
  console-setup: Depends: initramfs-tools (>= 0.85eubuntu12) but it is not installed
  dmsetup: Depends: initramfs-tools but it is not installed
  kbd: Depends: initramfs-tools but it is not installed
  linux-image-2.6.32-38-generic: Depends: initramfs-tools (>= 0.36ubuntu6) but it is not installed
  ntfs-3g: Depends: initramfs-tools but it is not installed
  plymouth: Depends: initramfs-tools but it is not installed
  udev: Depends: initramfs-tools (>= 0.92bubuntu63) but it is not installed
  watershed: Depends: initramfs-tools but it is not installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies
EDIT1
apt-get --reinstall install initramfs-tools
The following NEW packages will be installed:
  initramfs-tools
0 upgraded, 1 newly installed, 0 to remove and 921 not upgraded.
1 not fully installed or removed.
Need to get 49.0kB of archives.
After this operation, 372kB of additional disk space will be used.
Get:1 http://in.archive.ubuntu.com/ubuntu/ precise-updates/main initramfs-tools 0.99ubuntu13.1 [49.0kB]
Fetched 49.0kB in 9s (5,302B/s)
Selecting previously deselected package initramfs-tools.
(Reading database ... 140222 files and directories currently installed.)
Unpacking initramfs-tools (from .../initramfs-tools_0.99ubuntu13.1_all.deb) ...
Processing triggers for doc-base ...
Processing 1 changed doc-base file(s)...
Registering documents with scrollkeeper...
Processing triggers for man-db ...
Setting up initramfs-tools (0.99ubuntu13.1) ...
cp: not writing through dangling symlink `/etc/initramfs-tools/modules'
dpkg: error processing initramfs-tools (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of watershed:
 watershed depends on initramfs-tools; however:
  Package initramfs-tools is not configured yet.
dpkg: error processing watershed (--configure):
 dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
 initramfs-tools
 watershed
Tarun
  • 4,275
  • 15
  • 53
  • 74
The problem was caused due to symlink so I created one using the command
ln -sf /etc/initramfs-tools/modules.AfterVMwareToolsInstall /etc/initramfs-tools/modules
then
mv /etc/initramfs-tools/modules{,BAK}; sudo touch /etc/initramfs-tools/modules
then
dpkg --configure -a
and
apt-get -f install
It was a problem related to VMware module.
Thanks again to fossfreedom and Oli
Tarun
  • 4,275
  • 15
  • 53
  • 74
