I installed ubuntu 12.04 on my laptop for first time and every thing work well but the only thing doesn't work is the brightness doesn't change when I press F5 and F6 with Fn
So I can't adjust the Brightness and sometimes I need to decrease it for more time working on battery
and the bubble appear that it changed but nothing happens
My laptop is Sony VAIO series F with NVIDIA GEFORCE ...
and NVADIA accelerated graphic driver is activated
amrro
  • 535
LCD Brightness Control
Once you have installed the proprietary Nvidia drivers as suggested above, you may notice that your brightness control keys do not work properly. This is fixable by editing one's xorg.conf file. Open a terminal window and type the following:
sudo nano /etc/X11/xorg.conf
This will open your X server configuration (after prompting for your password). You should see a section titled "Device" that looks as follows:
Section "Device"
        Identifier      "Default Device"
        Driver  "nvidia"
        Option  "NoLogo"        "True"
EndSection
Append a line so it appears like this:
Section "Device"
        Driver  "nvidia"
        Option "RegistryDwords" "EnableBrightnessControl=1"
EndSection
You will need to restart your graphical server (or reboot) for this change to take effect.
amrro
  • 535
If installing all updates and rebooting does not work, try installing nvidiabl,
a little Linux driver [...] that enables the control of laptop backlight connected to NVIDIA chip using the /sys/class/backlight interface.
It worked for me on an HP Elitebook 8570w.
gertvdijk
  • 69,427
