Disclaimer First:
Now the Problem
I have installed Ubuntu 12.10 (64bit) in this Sony Vaio laptop. After vanilla isntallation the brightness keys are working and I can see the brightness indictaor going up and down but it isn't having any effect on the real brightness of the device.
I have installed additional drivers too but that didn't solve the problem. I can't seem to be able to change the brightness.
Anyone knows how I can fix this?
the only way to change brightness is to use this command
sudo su
echo 150 > /sys/class/backlight/intel_backlight/brightness
all other solution does not work at the moment. this is not my work around. i dont remember where i got this but it works and hats off to the person who gave this workaround :)
Using Ubuntu 13.10 64Bit Wubi on Lenovo Z570
Try modifying /etc/default/grub changing the line: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash" to GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_backlight=vendor"
Then run sudo update-grub
If it doesn't work try changing the same line to GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi_osi=Linux acpi_backlight=vendor" and update-grub again.
To Do
  • 15,833
I was finally able to solve the issue. Hence posting for the help of others coming to this post using search.
None of the techniques shown above worked for me. But goto the AMD's website (I have Radeon 7670 HD) and download their linux BETA driver which will solve your issue.
