I am using Ubuntu 12.04. Is there any way to lock the screen or session from a terminal command or script?
Simple:
gnome-screensaver-command -l
The following can also work, if the screensaver is set to lock when activate (see screensaver settings), since the command activates the screensaver:
gnome-screensaver-command -a
You can add an alias to the command by editing the file .bashrc (or .bash_aliases) in your home directory:
gedit $HOME/.bashrc
and adding the following line:
alias lock='gnome-screensaver-command -l'
Then from terminal:
source .profile
This will activate the alias.
From now on, the alias lock in a terminal will have the effect of locking the screen.
In addition to what January said, this also works:
gnome-screensaver-command --lock
or
According to the gnome-screensaver-command man page...
-l, --lock Tells the running screensaver process to lock the screen immediately
-a, --activate Turn the screensaver on (blank the screen)
For further clarification, here is another question/answer (also by January) which describes the differences between invoking the lock and activating your screensaver:
Difference between gnome-screensaver-command -a and gnome-screensaver-command -l
Starting in Ubuntu 14.04, Unity's lock screen no longer uses gnome-screensaver. The command gnome-screensaver-command -l will still work in most cases, but see this question for exceptions.
If that command does not work (say, for instance, that gnome-screensaver is not installed), bringing up the proper Unity lock screen (not the greeter where you can switch users) can be done via this command in a terminal:
dbus-send --type=method_call --dest=org.gnome.ScreenSaver /org/gnome/ScreenSaver org.gnome.ScreenSaver.Lock
- 36,890
- 56
- 97
- 151
- 8,925
Please install vlock. Then you can switch to a VT (text terminal, using Ctrl+Alt+F1) and run
vlock -a -s
This works whether you have X11 running or not.
- 7,235
- 10
- 40
- 47
- 191
A dirty hack of using the shortcut Ctrl+Alt+L for the locking the screen from a terminal:
Install xdotool from the software center or from the terminal as follows:
sudo apt-get install xdotoolType the following to lock the screen from the terminal:
xdotool key Ctrl+alt+l
Refer to the manual page for xdotool for more.
- 28,567
It depends on your display manager.
I have lightdm, I can do dm-tool lock to bring up a lock screen. It's not really secure, though, I found an easy way to bypass it.
- 2,229
A similar situation to lock the screen in lubuntu
in lubuntu 17.10 (not ubuntu) this works xset dpms force off
- 2,044
