I was trying to figure out difference between
gnome-screensaver-command -a
and
gnome-screensaver-command -l
According to the gnome-screensaver-command man page...
-l, --lock                 Tells the running screensaver process to lock the screen immediately
-a, --activate             Turn the screensaver on (blank the screen)
For me in both the cases it generated the login screen.Can some one outline the difference in the two things??
haziz
  • 3,067
I think that depends on the gnome-screensaver settings.
  • If you set your gnome screensaver not to lock the screen, than the -a option will not lock the screen.
  • If you set your gnome screensaver to lock the screen, then -a will lock it; this is the default setting in Ubuntu as far as I remember.
  • Option -l, however, will always lock it.
January
  • 37,208
The help is accurate. It describes what they're supposed to do.
Your scenario suggests X is crashing and I would suggest filing a bug (via ubuntu-bug gnome-screensaver) and seeing where that takes you. It could be something as silly as the particular screensaver you have selected (try another).
Oli
  • 299,380
