Possible Duplicate:
Fixing Broken Packages
How to install Libreoffice 3.5.4 in Ubuntu 12.04?
What is wrong with Ubuntu repositories?
sudo apt-get install libreoffice
Reading package lists... Done
Building dependency tree
 libreoffice : Depends: libreoffice-core (= 1:3.5.4-0ubuntu1.1) but it is not going to be installed
               Depends: libreoffice-writer but it is not going to be installed
               Depends: libreoffice-calc but it is not going to be installed
               Depends: libreoffice-impress but it is not going to be installed
               Depends: libreoffice-draw but it is not going to be installed
               Depends: libreoffice-math but it is not going to be installed
               Depends: libreoffice-base but it is not going to be installed
               Depends: libreoffice-filter-mobiledev but it is not going to be installed
               Depends: libreoffice-java-common (>= 1:3.5.4~) but it is not going to be installed
               Recommends: libreoffice-gnome but it is not going to be installed or
                           libreoffice-kde but it is not going to be installed
Solution is to force version of the package libexttextcat-data to 3.2.0-1ubuntu1 (not to 3.3.1-2~precise1 by default). When I tried to upgrade on version 3.3.1-2~precise1 whole libreoffice is marked to remove.
michal
  • 137
Go to synaptic package manager (download it if you don't already have it). Try and see if you have any packages installed mentioned in your post (use filter) and then go to the menu select Edit > Fix broken packages.
Alternatively, if you have recently installed Ubuntu using Wubi, I noticed the other day that Quantal Quetzal beta or alpha is currently being used. This is not stable and I had a lot of "broken packages". If that's the case, I don't have the skills to help you further. You'll probably need an alternative arrangement e.g.: - dual boot (caveat: do your homework extensively before attempting this); - installing Ubuntu in VirtualBox or VMware.
Simon Hoare
  • 366
