-1
I installed Ubuntu 12.04 LTS on my Samsung 305U notebook. The thing is when I close de lid it does't resume from suspension, the same problem reported Here. I removed the proprietary video drivers from system settings and it fixed the problem but videos runs choppy.
I tried to install ATI Catalyst drivers as shown Here I couldn't do it the way it was explained because it was impossible to install ia32-libs. Then I tried the second most voted aswear:
cd /tmp && wget -O amd-driver-12-6-x86_64.run http://goo.gl/XBFyI
chmod +x amd-driver-12-6-x86_64.run
sudo sh amd-driver-12-6-x86_64.run
This way I was able to install ATI Catalyst, presumably in it's 12.6 version, but when I rebooted I got a "Unsupported AMD Hardrive" watermark it lower-right side of the screen.
Does that mean ATI Catalyst aren't installed properly? Is there any way to fix it? All I need is the notebook to resume from suspension while having the video drivers properly installed.
install it from the application of ubuntu -> additional drivers, it worked for me
user84911
  • 1,101
I am suspecting you may have installed the x64 drivers instead of the x86
Please confirm your machine is not 64bit. Your best course of action in this case is to follow the instructions on the previous Q&A direction from the start, ignore references for 64 bit only and be sure to download the x86 driver. Please advise AU if you experience any further issues
stephenmyall
  • 9,885
Hi I have the same laptop I use 64b its OK I used to run 11.10 and that was a nightmare as each time I ran upgrades it overwrote the Radeon driver. I learnt to re-install quickly but still a pain. I have now installed the 12.04 64b and it worked without Radeon drivers and screen times out without having to re-boot each time. But its still runs very hot (I suspect the high level video card is going constantly) and I would like to know how to deal with that as its a pity to brun the laptop out one day.
But my suggestion to you is try the latest 64b and it should now screen save etc without problems. If your still stuck let me know Thanks
Antony
  • 1,453
