I just bought a Samsung NP305U1A laptop and installed Ubuntu Desktop 12.04 LTS on it.
Whenever I suspend the computer and try to wake it back up, the monitor only shows a black screen and the only thing I can do is a hard reset.
Kernel: 3.2.0-24-generic
Graphic: Radeon HD 6320
Anybody know what to do?
UPDATE
I did some some research and remebered that I installed the "ATI/AMD proprietary FGLRX graphics driver" from the "Additional drivers" software bundled in Ubuntu.
I also tried to install the "ATI/AMD proprietary FGLRX graphics driver (post-release updates)" but whenever I do, it gives me an error and I can't continue
So I decided to make a clean install of Ubuntu 12.04 again and when i tried the suspension out-of-the-box, it did work.
But since I can't install the drivers I need, HD video is choppy like hell.
So perhaps the suspension bug was fixed in the post-release updates of the driver, but sadly I cannot install them, and I don't know why.
You didn't specify which graphics card drivers are you using. With your graphics card it can be either the open source ones, embedded into the kernel, or the proprietay ones that come with the Catalyst management software.
If you are using the proprietary ones, I suggest you try and uninstall them; then you can test wether it was their fault or not.
If you didn't install the Catalyst suite, you can download it here to make the reverse test.
Tell us how it went. :-)
Eliah Kagan
  • 119,640
I had the same problem with Xubuntu on an Acer Timeline Aspire. Uninstalling the ATI Catalyst appears to have solved the problem. The laptop now resumes after hitting the space bar and requests the password; once entered the system is again fully operational.
